Old 06-10-2009, 12:50 PM   #1
2005 19' Safari
Dania Beach , Florida
Removing Numbering on my Trailer
Newbie here... With what might be a silly question!
I have just acquired my first Airstream Bambi and I'm not sure what the large red numbers are, that are on the front of back of my Bambi.
Were these originally lot numbers?
Do I really need them, or can I remove them?
KozyKamper is offline   Reply With Quote
Old 06-10-2009, 01:10 PM   #2
The handy accountant
pageclot's Avatar
1976 27' Overlander
Scarborough , Ontario
Images: 21
They are probably the previous owners WBCCI member number (WBCCI = Wally Byam Caravan Club International, an Airstream owners club).
You can do anything you want with your Airstream, up to and including belt sanding off the numbers. Or, if you want to join the WBCCI, you can inquire as to whether that number is available, and take it over if it is.
Welcome!
_____
Kevin and Leah
Accountants who tow sans regret
"I nostri cuori e le menti appartengono al flusso d'aria"
pageclot is offline   Reply With Quote
Old 06-10-2009, 01:13 PM   #3
SteveH's Avatar
Common Sense , Texas
First, welcome to the forum. The red numbers are WBCCI (Wally Byrum Caravan Club International) member numbers. They are assigned to the person/s that belong to the club, not the trailer. If you want to join the club, there is a chance that the previous owners are no longer WBCCI members, and the number is available, and in that case you can use the numbers. Otherwise, you should remove them. They are vinyl stick-ons and can be peeled off using a small amount of heat, like from a hair dryer.
Old 06-10-2009, 01:14 PM   #4
2008 28' Safari SE
winter garden , Florida
they would be registration numbers for the wally byam caravan club international or WBCCI. I am not sure if they transfer with a new owner
bob34787 is offline   Reply With Quote
Old 06-10-2009, 03:26 PM   #5
StingrayL82's Avatar
San Angelo , Texas
Images: 37
If you do decide to take the numbers off, be prepared for "ghost numbers"....the aluminum under the numbers isn't faded like the rest of the trailer, so the numbers will still be visible.
I'd leave them on, if it were me.....unless you feel like stripping the trailer and polishing it, then you wouldn't see the numbers.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 06-10-2009, 03:41 PM   #6
Lothlorian's Avatar
Loganville , Georgia
I was able to get my numbers off but some of the glue would not come off. For the last year I watched the magic of the sun slowly get rid of the glue over the numbers. The glue that held those numbers does not want to come off. I tried every type of chemical or solvent on the market. I will let the sun get rid of the glue over time.
The person above is correct about ghost numbers. You will always have them unless you polish your trailer.
Lothlorian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 06-10-2009, 05:15 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Soften them up a bit with a hot air gun then they should be easier to remove with a plastic putty knife.
Try WD 40 or Goo Gone to get the residue. You can polish them off too. But then you will have to polish the rest of the trailer to match.
Prep for numbering our AS FordTruck On The Road... 2 01-22-2009 10:15 AM
segment/panel numbering mswartz Ribs, Skins & Rivets 1 07-01-2006 06:54 AM
Removing a Stove dbaur Stoves, Ovens & Microwaves 2 04-17-2006 03:52 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
Numbering of Threads Suggestion hex Forum Admin, News and Member Account Info 6 04-21-2003 08:42 PM
