Old 11-09-2012, 07:50 PM   #1
ragin-cajun's Avatar
1961 16' Bambi
Malden , Missouri
Removing name plate?
I'm stumped on this one ...
Is there a way to take this off to polish underneath or is there a trick to polish with it in place?
ragin-cajun is offline   Reply With Quote
Old 11-09-2012, 08:38 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
You have to take the interior skins off to get the emblem off. It has posts with things that I don't know the name of.....the closest I can come to explaining them is that they're square & have a hole in the middle--they push on & need to be pried off from the inside. Just alot of tedious polishing, I'm afraid..
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-09-2012, 09:23 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
When I had my Buick's body and paint redone they worked a 'putty' knife behind the name plate at the mounting posts then gave the knife a sharp hit with a hammer. To NOT scratch the aluminum use a plastic knife. To remount the name plate they used a double side tape made just for that. That tape is available at auto paint supply stores. The tape is first applied to the back of the name plate then trimmed around, then mounted on the coach. You have to get it exactly on where you want it as this tape is almost permanent.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 11-09-2012, 11:16 PM   #4
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I'd Polish around it if I was you. I think VTS or Caswell has small polishing tips that may help you.
desertair27 is offline   Reply With Quote
Old 11-10-2012, 04:59 AM   #5
1961 16' Bambi
Malden , Missouri
Well, while I appreciate the input, I have to say that I don't "like" any of your answers! 😉
I was afraid that there was a back-side trick to it for it to have held these 50+ years. I really want to maintain as much original as possible, so I think I'll opt for the tiny polishing tools.
Thanks for the help, everyone!
Old 11-10-2012, 08:03 AM   #6
Mixter's Avatar
1976 27' Overlander
Here's from my manual for 76. Manual says "when access to the backside is not possible, cut into the skin to gain access, then rivet new piece over it"... I'm tearing mine down inside, so I'm going to see if I can access the back side and remove them with reasonable effort. I dont think I'm going to remove a bunch of skins in an area where I'm not working just to do this though. I'll probably just try and work around it. Was looking at Harbor Freight last night and see they sell some small dremmel- type tools for polishing the small areas for cheap. Hope this helps- good luck! Micky
Name:	AS Letters attachment.jpg
ID:	172410   Click image for larger version
Name:	AS nameplate attachment.jpg
Mixter is offline   Reply With Quote
