Old 07-28-2009, 01:17 PM   #1
utahredrock's Avatar
1962 22' Safari
1973 25' Tradewind
1968 30' Sovereign
Salt Lake City , Utah
Removing mineral deposits on exterior
Any tips or dos and dont's for removing minderal deposits from the area of my water heater? They've slowly built up over time, overflow I guess.
Thx.
Jim Breitinger, Salt Lake City
Former full-timer (2007-2009) Airstream tribute blog.
Brief revival in 2017, the year of my '62 Safari
Follow me on Instagram: https://www.instagram.com/jimbreitinger/
utahredrock is offline   Reply With Quote
Old 07-28-2009, 01:18 PM   #2
1962 22' Safari
1973 25' Tradewind
1968 30' Sovereign
These are on the exterior/aluminum . . .
Old 07-28-2009, 01:24 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have never had the problem but CLR comes to mind. Here in NM we have hard water and use CLR a lot. I don't think it would hurt aluminum, but do a test.
Old 07-28-2009, 02:22 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Something that I have had success with is plain white vinegar -- it can be used straight or mixed with water. For heavier deposits straight white vinegar heated slightly and rubbed on with a sponge should dissolve most water deposits without harming the aluminum -- as with moth cleaners, rinsing after application is always a good idea.
Kevin
Kevin D. Allen
AIR #827
Old 08-02-2009, 09:24 AM   #5
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
CLR in hot water, delute with some water but make a strong mixture...sponge it on and it will take the rough off but will probably leave a watermark in the metal, which you will have to polish out with a strong compound first (we use 3M super duty (gravel in a bottle) rubbing compound) will remove the stains with hardly any rubbing, but you will see it disappear. then polish with mothers. 3M super duty is about 15.00 a quart and its a squeeze out cream...your gonna love it forever.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Question about white aluminum oxide deposits williamhenshall Ribs, Skins & Rivets 11 04-02-2008 12:44 PM
Avoid Mineral Spirits / Petroleum Products? MartyK Cleaning, Stripping & Polishing 9 11-26-2007 05:24 PM
removing hard water deposits djfrantic Cleaning, Stripping & Polishing 11 10-11-2007 03:07 PM
Polishing/mineral spirits davidz71 Cleaning, Stripping & Polishing 13 08-07-2005 07:43 PM
removing old add on parts from the exterior (pics) Swingking Exterior Restoration Forum 11 07-16-2003 03:11 PM
