1976 31' Sovereign
2000 33' Land Yacht
Ball Ground
, Georgia
Removing glue
Just purchased a 1969 Sovereign . The previous owner took good care of it except. Loved to put lots of decals on it. I plan to try to remove them with a heat gun but any suggestions on a solvent to cut the glue. Latter I will use remove-all to strip the clear coat so I won't worry about the finish. Thanks
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
2010 30' Classic
South of the river
Any solvent that is effective is also hazardous, so be careful, read labels, and take precautions.
I find that a heat gun is most effective for initial removal. I use acetone for final cleanup. It will dissolve the clearcoat, and is extremely flammable, but is less toxic than some of the other solvents.
Rapid Remover. Sold on Amazon. Gets decals and adhesive off in a snap. Used by folks doing vinyl signs.
