Old 02-02-2014, 05:12 AM   #1
1973 Argosy 28
yoakum , Texas
removing exterior paint
Recently we have purchased a 1973 Argosy, in which the previous owners, (now deceased), had painted. Looks like it was NOT sanded,or prepped in any way. Pretty much looks like they took some cheap paint and sprayed it on. Of course, it is peeling and we want to strip it off. However, we would like to get suggestions from others who have removed paint ,successfully.
TheFerrys is offline   Reply With Quote
Old 02-02-2014, 05:44 AM   #2
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Any type of aircraft stripper will work like removALL 220. Here is a link for Vintage trailer supply.
RemovAll 220
You can also use stuff from the big box stores, but this stuff is tried and true on aluminum.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 02-02-2014, 05:46 AM   #3
wxbuoy's Avatar
Just realized they no longer have a source for removeALL 220 and are recommending this:
Eldorado PR-5044 Paint Remover
Dave and Felicia
Old 02-02-2014, 06:06 AM   #4
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
I took mine to a guy who paints airplanes.
Stripped all the old paint with an aircraft aluminum stripper.
Primed with a gray epoxy primer.
Coated with 08 Toyota Tundra metallic silver. Gloss black for banana wrap.
Airstream Blue on bottom rail (to match new rub rail insert).
Painted the Argosy logos blue.
Painted the rims metallic silver.
Toped off with 2 clear coats.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 04-28-2014, 09:08 PM   #5
Swanstreaming
swan's Avatar
2014 28' International
Zionsville , Indiana
Send a message via Skype™ to swan
Photo?
Instagram.com/swanstreaming
swan is offline   Reply With Quote
Removing curtains for cleaning CAMP AIR Upholstery, Blinds, Walls & Interior Finishes 24 04-10-2018 07:48 PM
Removing the WBCC letter without doing damage to clear coat perryg114 Clearcoat, Exterior Paint & Trim 7 10-27-2011 11:45 AM
Removing Dinette Material Rust Upholstery, Blinds, Walls & Interior Finishes 6 10-11-2011 03:22 AM
Removing vent pipe without cutting? bennyg Ribs, Skins & Rivets 0 07-05-2011 04:42 PM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
