Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 01-08-2008, 11:47 PM   #1
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Removing Duct Tape Residue
What are your recommendations for removing old duct tape residue from exterior skin? I tried Goo Gone with not too much success.
Just another jack rabbit at a coyote picnic
Lumatic is online now   Reply With Quote
Old 01-09-2008, 12:08 AM   #2
mweels
mweels's Avatar
Profile:  1977 25' Tradewind
Modjeska Canyon , California
Removing Duck Tape..
Bug & Tar remover worked great on painted bumpers. I am not sure how it would work on a trailer.
Marty
Shannon
Lily
North
77' Tradewind
mweels is offline   Reply With Quote
Old 01-09-2008, 07:24 AM   #3
Royce
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I have used WD-40 and Goof-Off, both with success. Caution regarding the Goof-Off, it can remove things you don't want removed. Goof-Off is much different than Goo-Gone.
Try a search of the forums, you will find the topic discussed in detail.
Royce (K0RKK) and Karen
AIR# 3913
Royce is offline   Reply With Quote
Old 01-09-2008, 07:29 AM   #4
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Be careful if you've got any clearcoat on there. I used mineral spirits and a soft cloth on my Argosy. It was tough! I swore off doing that again but it's still in my toolbox. I'd sure never use duct tape on my Safari.
Old 01-09-2008, 07:42 AM   #5
Lumatic
Lumatic's Avatar
1962 28' Ambassador
The American Way/ Apple Pie and Duct Tape
The clearcoat has been previously stripped.
My recent experience was a desperate act of the last resort, when both of my wing windows blew out on the 2nd day of a month long road trip. Otherwise I would rather sleep in a trailer full of cats in heat. I anticipated the problems I would have getting it off, and as usual I am right again
FYI
I saw a TV news piece comparing duct tape to other products for sealing ducts. Duct tape turned out to perform worst.
Old 01-09-2008, 09:38 AM   #6
jkcru
jkcru's Avatar
Profile:  1976 23' Safari
Escondido , California
Try a rag soaked in WD40 and masking it over the residue till it soaks in then try to wipe the surface clean.
jkcru is offline   Reply With Quote
Old 01-09-2008, 09:48 AM   #7
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I have had a lot of success disolving different glues with plain old liquid lighter fluid, and I have been using regularly for the last 40 years. I have never found it to harm any surface that I have used it on. Try some and leave it sit on the surface for a couple of minutes.
Lighter fluid is the same as Naphtha, and you can buy in a one quart can in the paint department at Home Depot for a much better price.
You also might try a hair dryer on a small spot to see if the heat will soften the glue up any.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 01-09-2008, 11:32 AM   #8
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
Lighter fluid cigarette/charcoal is naptha. It is a good choice. You can also buy it by the naptha name at ACE but it is likely to cost you more per pint.
Old 01-09-2008, 01:57 PM   #9
nine9three
Profile:  2007 25' International CCD
Corvallis , Oregon
3M adhesive remover. Best product out there. Look for a red and white can
nine9three is offline   Reply With Quote
Old 01-09-2008, 07:38 PM   #10
62overlander
not the shiniest rivet
62overlander's Avatar
Profile:  1962 26' Overlander
Catonsville , Maryland
MEK excuse the spelling for MEK is what it says on the can. Methy etheyl ketone. It will remove anything from anything. it will remove your memory if you inhale it so wear a mask. and it will sink into your skin faster than it will evaporate so wear gloves. It will take it off quick. Happy removal and hallucinations.
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
62overlander is offline   Reply With Quote
Old 01-09-2008, 09:01 PM   #11
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
De-Natured alcohol. Milder version of Acetone and MEK.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 01-09-2008, 11:19 PM   #12
tetstream
tetstream's Avatar
Profile:  2007 19' Bambi
Somewhere , Between the Tetons and the SF Bay
Xylene is also a choice, but a bit "hotter" than Naptha. In my experience it is better to use a stronger solvent and less elbow grease. Assuming that the solvent does not react with the finish, this is the best way I know. Elbow grease = abrasion.
But, be warned. I removed a bit of sticker adhesive from the interior of my bambi with a very soft rag and small amount of xylene and ended up with some light swirls.
Try to remember in the future to use a hair dryer or heat gun to help remove stickers and tape. Seems to leave little or no adhesive.
TT: 2007 Bambi 19' 75th Anniversary Special Edition
TV: 2006 Chevy HD2500 Duramax 6-speed manual
tetstream is offline   Reply With Quote
Old 01-10-2008, 10:52 AM   #13
safari57
safari57's Avatar
Profile:  1951 21' Flying Cloud
West Coast , BC
Lumatic,
You realize you have to tell us what you ended up using and what worked.
There are some of us out here with the same problem and are watching with keen interest as to what you find out, given our own need to remove the glue is a little less urgent.
Barry
Take care. Unlike your puppy, it is so embarrassing to put your Airstream to bed belly up.
Barry & Donna
Life is short - so's the door on an Flying Cloud (ouch)
1951 Flying Cloud 21'
1957 Pontiac Safari 2dr wagon TV
AIR #7364 WBCCI #8110 member 4CU
safari57 is offline   Reply With Quote
Old 01-10-2008, 01:05 PM   #14
Lumatic
Lumatic's Avatar
1962 28' Ambassador
3m
Originally Posted by safari57
Lumatic,
Barry
The above post about the 3M Product triggered a flashback. "I think I have that stuff" popped up in my mind. I just ran into my garage and sure enough I have a quart of 3M General Purpose Adhesive Cleaner. The label says it contains xylene, naptha, trimethylpentane, toluene, ethylbenzene, and benzene. A pretty toxic soup. I ran out to my trailer and it seems to cut through the poop purdy good. The can says it "will not dissolve or mar automotive paint that has been properly aged". I don't know what that statement means as far as clear coat is concerned as I stripped my clearcoat and polished the aluminum.
skin oxidation and red letter residue remover/ it works Lumatic Cleaning, Stripping & Polishing 0 09-08-2007 05:43 PM
Duct to nowhere walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-17-2004 07:16 PM
Duct Tape Popup fireflyinva Off Topic Forum 10 12-05-2004 05:54 AM
Why the battery residue? Kistler Batteries, Univolts, Converters & Inverters 3 11-15-2004 05:39 PM
speaking of "Duct Tape".... Chuck General Interior Topics 5 09-17-2004 08:24 AM
