Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 07-13-2007, 10:34 AM   #1
KHarris
69 Caravel
KHarris's Avatar
Profile:  1969 18' Caravel
Bayfield , Colorado
Removing the awning for polishing?
I am wondering what to do about the awning while I polish our '69 Caravel. It's original, not a ZipDee or Carefree, and may even be a brand that's no longer available. It appears to slide into a bead style track on top.
My concern about removing it entirely, after reading so many awning threads, is that I will run into problems reinstalling it, particularly with tension (the awning's, not mine).
I'm sure lots of you have done this before though, any suggestions?
Thanks for your help.
Krista
I Dream of Airstream!
KHarris is offline   Reply With Quote
Old 07-13-2007, 11:00 AM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Krista
Krista,
Generally, I think it is a good idea to remove as many obstacles as is practical from the trailer before polishing.
However, I do feel that it is important that you identify the awning, and get some sort of manual or other information about it, to make sure that the removal process is safe and does not damage the trailer, awning or even worse, vital and much needed body parts of yourself.
There is a fair amount of tension onthe spring loaded roller. Just taking out hardware will most likely end up being painful...if not on yourself, then on your wallet.
Uwe
Old 07-13-2007, 11:23 AM   #3
klevan
klevan's Avatar
Profile:  Albuquerque , New Mexico
Another Approach...
Depending on the design of the awning, you may cause it to lift vertically upward and give you enough clearance to polish beneath it by leaving the awning arms partially extended and gently allowing the awning to retract into its case.
This process leaves the awning partially unrolled, straight up in the air. At least this is what happens with a Zip Dee.
Caution: If your awning is dry rotted or worn out, it may stress it.
Examine it very carefully. Send us some pictures.
Ken Levan
2005 Chevy 2500 HD Duramax/Allison
Formerly WBCCI #8654
klevan is offline   Reply With Quote
Old 07-13-2007, 11:35 AM   #4
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Krista
Airstream has never made an awning.
Therefore you cannot have an "original" awning.
Please post a couple of photo's especially a closeup the the arms.
From those photo's, several people could then help you.
CAUTION: Do not attempt to remove the awning until it is identified.
The roller tube should have a spring in it that has considerable tension stored.
If you release that tension, and don't know what to expect, it could severely injure you up to the point of death.
Posting photo's will eliminate that for you.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 07-14-2007, 08:17 AM   #5
KHarris
69 Caravel
KHarris's Avatar
Bayfield , Colorado
Photos of awning
Thanks everyone for your advice and comments.
A picture is worth a thousand words as they say. I should have done this in the original post, sorry. Here's my awning. If anyone know what kind it is, I'd be interested. There was no documentation for it when I purchased the trailer and I am still looking for identifying marks.
So far I have managed to wrap some protective plastic around the rolled-up awning, propped it up a little more and begun the clearcoat removal with fair success.
Old 07-14-2007, 09:36 AM   #6
craftsman
craftsman's Avatar
Profile:  2007 25' Classic
Hydes , Maryland
I think she meant original to the trailer not that Airstream made it because she does say that it "may be a BRAND that's no longer available.
Craftsman
craftsman is offline   Reply With Quote
Old 07-16-2007, 12:37 PM   #7
Commercial Vendor
It appears that your awning is an old style Carefree, but it could possibly be an A & E as well.
Hate to tell you, but from your photo, it appears that your axle has had it.
The following article will help you check it out yourself.
Dura Torque Axle
Inlandrv.com
800-8777311
Old 07-21-2007, 07:04 PM   #8
klevan
klevan's Avatar
Zip Dee on Its Head
I finally got around to taking a picture of my Zip Dee "standing on its head." I know you have a Carefree, but the same principal should work to give you access to the skin beneath the rolled up awning. Good Luck!
Ken Levan
Old 07-22-2007, 10:07 AM   #9
mello mike
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 22
Excellent, thanks for the tip! I really didn't want to remove the awning for this process. BTW, what are the stripes I see on your Airstream?
2003 Ford Excursion (6.0L PSD)
Prodigy / Equal-i-zer / Honda EU2000i / Xantrex Link 10
U.S. Navy (Retired)
Airstream Life Contributor
Air#5661 / WBCCI#--
My Refurb Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-22-2007, 11:20 AM   #10
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
The roof structure being reflected in the polished aluminum skin.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 07:49 PM
Awning Heads Up!!! JaceBeck 1999 Safari 39 04-25-2006 06:31 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 08:34 AM
Awning gwrimmer General Motorhome Topics 1 11-07-2002 12:59 PM
Awning Repair cesurman Awnings 0 08-16-2002 12:57 PM
