Old 09-08-2009, 08:18 PM   #15
papagord's Avatar
1974 25' Tradewind
Midhurst , Ontario
You've done a great job.....looks good! Gives me some hope that with effort I can get mine to shine!! Thanks for the pic.
papagord is offline   Reply With Quote
Old 09-08-2009, 10:33 PM   #16
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by InsideOut View Post
I believe we got everything at Caswell's, I have a list of the buffs & bars, which I can post later.
Okay, so I checked w/Mr.InsideOut here is what he purchased:
(1) - GA58 Grinder/Buffer Adapter
(2) - SSCW1220 Spiral Sewn Cotton Wheels
(2) - LCW1240 Loose Cotton Wheels
(1) - BRBC5 Brown Tripoli Bar
(1) - WR995 Wheel Rake (for cleaning & fluffing the wheels)
I was wrong - he didn't buy black bars, I had one from my shop - it is really to coarse for all but the worst blemishes, he's not using it much at all. Also, not using the rouge bar either...just the brown. The two buffing wheels are used at the same time to make the surface area bigger. The stitched wheels are for the first couple of passes and the loose wheels are to remove the scratches as a final pass before moving to the Cyclo Polisher. Like I stated earlier, I haven't been using these "big tools" I work on the details & trim so I wasn't as clear what exactly he was doing.
Anyways, hope this helps ~
Shari
Old 09-09-2009, 06:26 AM   #17
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You forgot to mention Rob's polishing hat. Picture from RMVAC #8.
Richard
Old 09-10-2009, 08:41 PM   #18
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
THE PO on my 71 told me i could remove the clearcoat with muratic and water mix 5 to 1. Is this true?
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 09-10-2009, 09:28 PM   #19
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
In regards to using acid washes, I have read NEVER use any acid on the skin of an Airstream.
This will cause leaks at the rivets.
I also have read you can use aluminum oxide sand paper on the worst of the corrosion. 300-400 grit.
I tried this on some places on my roof and it does remove the corrosion.
I then went over the spot with Nuvite polish. That process did help the spots on the roof.
ID:	86997   Click image for larger version
ID:	86999   Click image for larger version
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 04-27-2015, 03:58 PM   #20
beaumont , Texas
polish
I really like your results. I have done several vintage airstreams, and have used a lot of products initially. i ended up with all nuvite, all from vintage trailer supply. I would like to know more about yours with rouge.. I am familiar with buffing wheels and rouge, but for car parts, not a vertical surface like a trailer.I looked at caswells site and there are a lot of options. Could you be more specific in what you bought and what you think works the best.. thanks,, Richard in Texas.. I am starting my 75 international,, any thing that lessens the buffing effort would be great.. its a big trailer.
Dixie722 is offline   Reply With Quote
Touch Up Clear Coat?? Anniedog Clearcoat, Exterior Paint & Trim 11 03-29-2010 10:54 AM
Clear Coat not completely removed RichHog Clearcoat, Exterior Paint & Trim 0 05-27-2009 11:05 PM
Has Any One use microbille on clear coat? Perry Cleaning, Stripping & Polishing 6 12-10-2007 03:42 PM
Clear Coat on Everything! Sherry S Upholstery, Blinds, Walls & Interior Finishes 2 08-07-2007 08:13 PM
strip clear coat baobi Cleaning, Stripping & Polishing 3 05-28-2006 05:29 PM
