Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 11-21-2007, 10:56 AM   #1
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Question Removall 220
Yes I did a search, Does this stuff go thru blue masking tape after a few hours?
I assume the plastic light lenses need to be covered also along with the belt moldings.
What about the Wbcci vinyl numbers?
I already used other paint removers but there is a thin film left in many places how long did you leave it on?
I read that most people just hosed it off, correct?
Do I need gloves and goggles?
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Old 11-21-2007, 11:47 AM   #2
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Helena , Montana
If you are worried about the blue tape get some metal tape. Aluminum on a roll. Available at most hardware stores.
It is always a good idea to wear gloves and goggles when working with anything other than food. Seriously.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 11-21-2007, 01:08 PM   #3
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Naper RemovALL is a water-based paint and plasticoat remover that is biodegradable, non-toxic, user-friendly and environmentally safe. I've used it...it's very mild, yet still effective. You don't need gloves - it doesn't burn, but it's probably a good idea. But then, I didn't wear them...
It shouldn't eat up the tape...but it may be easier to remove the plastic lenses & such rather than tape them all up and then un-tape them afterwards. That way you know they won't get "the goo" on them.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 11-21-2007, 01:16 PM   #4
byamcaravanner
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
HERE is the Napier RemovALL 220 Material Safety Data Sheet (from the VTS website).
I agree that it would be better to remove rather than mask your running lights.
Have fun!
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 11-21-2007, 01:58 PM   #5
LI Pets
Silver Mist
LI Pets's Avatar
Ok, good info, thanks,
What about how long to leave it on?
WBCCI
Old 11-21-2007, 02:43 PM   #6
empresley
empresley's Avatar
Profile:  1984 34' International
1977 Argosy 24
Central , Georgia
Great product. User friendly.
Blue tape – I can’t comment on long term but I used the blue painter’s tape in two places: to cover the furnace exhaust after removing the protective screen guard and to wrap the open end of the propane supply line at the tongue. The tape has been there for two months and shows no sign of break down due to the stripper.
WBC numbers? No idea. I would not go to the trouble to protect existing. If they are damaged order another set.
I removed lens (both the ones with screws and some that are reflective and riveted in place) This was more about being able to apply stripper in every nook and cranny and also the removed lens were to be replaced with new.
The Removal product can be applied with a great degree of precision if you use a brush. I used a 4” nylon brush that lasted throughout the project. Just rinsed with the hose after each use.
I did not worry about window gaskets or any alum. trim. It just seemed to clean things up as we went along. Never noticed a “film” or residue but I washed each stripped section carefully. Photos attached are where I started stripping the Argosy’s rear (plastic or fiberglass) taillight housing. After a few hours I decided to remove the darn thing and replace with standard light assemblies.
My suggestion is to start at the top and work down applying stripper to manageable areas. I learned that using a large (4”) plastic scraper to remove the excess and then rinsing off with water and a soft brush worked really well. I never tried to blast off with even regular nozzle pressure just to minimize the chance of forcing water into the trailer.
My assumption is that you are removing clear coat and it may be harder to distinguish the effect as compared to watching paint blister and fall off.
For very stubborn and small areas I have been using the Takeoff Liquid. Use it with a spray bottle and scotch pad. Takeoff has a paste comparable to Removal but it does not cling to a vertical surface as well. Removal clings like crazy.
Yes, wear gloves and long sleeves. Eye protection should be there in case of a splash.
Removal is fairly friendly in terms of being a chemical but it should be handled with care. Follow direction on the can. It is a great grass killer for the areas in comes in contact. Since it is my neighbor's grass this was not a big issue.
ID:	49692  Click image for larger version
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is online now   Reply With Quote
Old 11-21-2007, 02:57 PM   #7
thecatsandi
Helena , Montana
If you decided to go the aluminum tape route use the handle of the screw driver to press the edges down. The tape will cut you up like a razor blade.
Michelle
Sarah
Old 11-21-2007, 03:00 PM   #8
toastie
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
, , Michigan
RemovALL 220 Industrial paint remover Brush Grade great stuff.............
toastie is offline   Reply With Quote
Old 11-23-2007, 10:53 AM   #9
LI Pets
Silver Mist
LI Pets's Avatar
Wow this stuff works!!!
Left it on 4 hours, hosed it off then wiped it with no scratch pad.
I had used several other brands, but they all left residue.
WBCCI
Old 11-23-2007, 11:15 AM   #10
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
What temperature is it where you are working? I would like to strip my endcaps but am alittle concerned it's too cold even here in Mississippi.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 11-23-2007, 01:53 PM   #11
byamcaravanner
From the Napier RemovAll 220 product data sheet:
"OPTIMUM TEMPERATURE:
Surface temperatures should be 65 to 95 F (20 to 32 C).
The product performs effectively at lower temperatures
(even at 32 F, 0 C), but the dwell time increases."
Steve & the crew
Old 11-23-2007, 03:00 PM   #12
CharlieE
Profile:  1990 34' Excella
Parsonsfield, , Maine
I used the 220 to strip my 34' and liked it very well. In very hot weather, like 80's it tends to flatten out on the surface and look like just an oil coating, but it will stay for hours, at least 4 in the shade. I flushed it off with a garden hose and nozzle. Sometimes I would not have enough product on my paint brush and it would spread too thin and after I flushed it off I would let it dry and recoat the misses. I also used non scrathing plastic pads for tough spots. A great product and I found it didn't kill my grass here in Maine or at the AS park in Florida. Charlie E.
CharlieE is offline   Reply With Quote
Old 11-23-2007, 04:55 PM   #13
LI Pets
Silver Mist
LI Pets's Avatar
I think it was about 55 when I started and 50 when I hosed it off.
WBCCI
Old 11-23-2007, 06:04 PM   #14
HiHoAgRV
Images: 26
Hummm, It's in the 40's here all day...
I'll give it a try when we warm up a bit, thanks!
Hi Ho Silver RV!
Removall stripper questions 63air Cleaning, Stripping & Polishing 11 03-13-2007 02:33 PM
Wow that removall is great Angel73 Cleaning, Stripping & Polishing 8 05-15-2006 08:50 PM
How to convert 220 AC/50hz to 120 AC /60hz brunoffrance Electrical - Systems, Generators, Batteries & Solar 5 12-28-2002 05:47 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
