Old 06-13-2014, 08:05 AM   #1
cmmorsey's Avatar
2008 23' International
carlsbad , California
Red Number Removal
Hello,
Looking for some solid solutions for removing red numbers on my new airstream. It's a 2008 so could have been on as long as 6 years or so. Would like to remove with no risidual signs of numbers.
Thanks for any help that can be offered
Name:	ImageUploadedByAirstream Forums1402668318.715913.jpg
Name:	ImageUploadedByAirstream Forums1402668288.746251.jpg
cmmorsey is offline   Reply With Quote
Old 06-13-2014, 08:09 AM   #2
SteveH's Avatar
Common Sense , Texas
Use a heat gun on low temp, or a hair dryer on high to heat them one at a time. They should peel off. You may have some adhesive residue left, and if you do, GooGone will take it off, and not do any damage.
Regards,
Steve
Old 06-13-2014, 08:12 AM   #3
cmmorsey's Avatar
Great... Thanks SteveH
Old 06-13-2014, 09:56 AM   #4
1974 Argosy 20
Kooskia , Idaho
When you get them removed, there still may be a ghost of them where the clear coat was covered, thus protected, and the remaindered was not. Just something that can't be changed.
Old 06-13-2014, 10:02 AM   #5
cmmorsey's Avatar
Idroba, if that is the case. I wonder if that's something that can be buffed out?
Any thoughts from the forum?
Old 06-13-2014, 10:10 AM   #6
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
You could leave the numbers on and join the WBCCI and request 4227.
But yes a heat gun to soften the numbers and they will peal off, I just removed the numbers on our to put on some new ones.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 06-13-2014, 10:24 AM   #7
1974 Argosy 20
Kooskia , Idaho
The newer clear coats may be more resistant to the ghosting, I simply don't know. Virtually all of the old ones would show the ghosting I mention when the numbers are removed. I have no idea about buffing the clear coat. I would suspect that just makes it thinner but someone here may know a lot more than I do about the subject.
Old 06-13-2014, 11:44 AM   #8
Silver Lamb
EweMama's Avatar
1969 27' Overlander
1961 16' Bambi
Bonner Springs , Kansas
If you will clearcoat the new numbers before putting them on, they will not fade. Will the new numbers hide most of the ghosting?
EweMama is offline   Reply With Quote
Old 06-13-2014, 01:25 PM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Goo Gone-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-15-2014, 01:46 PM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The ghosting is caused by the numbers protecting the surface below them. So the area around the numbers weathers and the numbers protect the finish. You pull the numbers and the protected areas become quite evident. The difference depends on the length of time, the uv exposure, and weather the trailer is exposed to.
My dealer told me to leave my numbers off. He said it would be easier to sell the trailer in the future if it stayed "bald". As it ended up I left WBCCI after 4 years. Glad I took his advice,
Jack
Jack Canavera
STL Mo.
AIR #56
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 07:58 AM
Seal Part Number I am repacking wheel bearings and seals have no part number. Ditter Wheels, Hubs & Bearings 9 05-05-2013 02:17 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
