08-15-2016, 06:38 PM
san jose
Random Orbital Polisher on newer AS?
I see a lot of threads for older AS utilizing power tools to polish, but I can not find much if anything pertaining to polishing newer AS with Random Orbital polishers.
Only by hand rcommended or success shining up (I know its not going to me mirror like) newer AS with random orbitals?
08-16-2016, 01:14 AM
2008 22' Safari
Spicewood (W of Austin)
If you'd like to really really REALLY make your life miserable.... then use a polisher on your newer model Airstream.
It will burn and melt the plasticizer-clearcoat on your aluminum turning it into a smeared, burned, blackened mess. Then you will have to chemically STRIP the entire trailer to bare aluminum... and THEN you'll HAVE to polish it regularly for the rest of it's life.
Do NOT attempt to polish a newer, clear-coated Airstream.
08-16-2016, 09:22 AM
san jose
Thanks for the reply, time to get the elbow grease out.
08-16-2016, 10:53 AM
1979 28' Ambassador
2014 27' FB Classic
Port Townsend
It is my understanding that the clearcoat put on the newer Airstreams is very much like the clearcoat put on cars. Is that is the case, using a dual action polisher like a Porter Cable 7424XP should not be an issue. They will not burn the clearcoat like a high powered orbital polisher.
08-16-2016, 11:03 AM
2013 25' Flying Cloud
Edisto Island
, South Carolina
I've used the Porter-Cable random orbit polisher on our 2013 Flying Cloud with good results. I use it on our clear coated cars also. No problems and makes the job easier.
08-16-2016, 12:20 PM
2014 25' FB Eddie Bauer
Vero Beach
I agree with #4 and 5. A 9" or 10" random orbital polisher (not a polisher like the vintage AS folk use for that mirror finish on bare aluminum) with foam (for wax application) and terry or microfiber (for buffing) bonnets can speed and ease the process of waxing without any damage to the finish on modern Airstreams.
Do not use polishes or cleaning compounds (per Airstream recommendations) which are abrasives. Just plain wax.
08-16-2016, 02:52 PM
2001 25' Safari
Ridgefield
I have a 2001 Safari I bought new. I use Meguairs Gold liquid wax and I apply it with a 10" Craftsman random orbiting polisher with the thin blue applicator pad made specifically for applying wax. Do not use the cotton fleece pad to apply or buff the wax. It will damage the clear coat. Wipe the dried wax off manually with an old soft towel. I wax once a year. I've done this for 15 years now and my AS still looks new. It's not the mirror finish of a highly polished vintage AS. It's the shiny clear coat finish of the newer Airstreams. I treat it like I treat my cars and truck which also have clear coat finishes. I get "it looks like new" comments every time we take our AS out.
08-16-2016, 11:10 PM
san jose
Much appreciated all. I will most likely try Griots One Step under the rock guards (most white blotches) with my Griots Random Orbital to test.
08-17-2016, 11:14 AM
1966 26' Overlander
Woodstock
if you want shiny- go vintage
08-17-2016, 11:50 AM
2015 28' International
Ofallon
Walkerize and a soft rag. Little elbow grease required.
08-17-2016, 01:21 PM
2008 22' Safari
It may be that a definition-of-terms be in order.
When I read "orbital polisher" ... I thought of a device to apply "polish" at high speed ...which will burn the clearcoat (a plasticizer type of synthetic covering used to fight oxidation on our modern Airstreams.)
If you only mean to "BUFF" using WAX... and don't "bear-down" and burn theclearcoating ... it should work fine.
But DON"T USE POLISH which has fine abrasive or defect-remover in it. You will ruin the clearcoat and injure it's purpose.
