Old 08-15-2016, 06:38 PM   #1
san jose , California
Random Orbital Polisher on newer AS?
I see a lot of threads for older AS utilizing power tools to polish, but I can not find much if anything pertaining to polishing newer AS with Random Orbital polishers.
Only by hand rcommended or success shining up (I know its not going to me mirror like) newer AS with random orbitals?
vis0rd0wn is offline   Reply With Quote
Old 08-16-2016, 01:14 AM   #2
Boxite's Avatar
2008 22' Sport
If you'd like to really really REALLY make your life miserable.... then use a polisher on your newer model Airstream.
It will burn and melt the plasticizer-clearcoat on your aluminum turning it into a smeared, burned, blackened mess. Then you will have to chemically STRIP the entire trailer to bare aluminum... and THEN you'll HAVE to polish it regularly for the rest of it's life.
Do NOT attempt to polish a newer, clear-coated Airstream.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-16-2016, 09:22 AM   #3
Thanks for the reply, time to get the elbow grease out.
Old 08-16-2016, 10:53 AM   #4
1979 28' Ambassador
2014 27' FB Classic
Port Townsend , Washington
It is my understanding that the clearcoat put on the newer Airstreams is very much like the clearcoat put on cars. Is that is the case, using a dual action polisher like a Porter Cable 7424XP should not be an issue. They will not burn the clearcoat like a high powered orbital polisher.
rdepas is offline   Reply With Quote
Old 08-16-2016, 11:03 AM   #5
Edistobob's Avatar
2013 25' Flying Cloud
Edisto Island , South Carolina
I've used the Porter-Cable random orbit polisher on our 2013 Flying Cloud with good results. I use it on our clear coated cars also. No problems and makes the job easier.
Edistobob is offline   Reply With Quote
Old 08-16-2016, 12:20 PM   #6
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
I agree with #4 and 5. A 9" or 10" random orbital polisher (not a polisher like the vintage AS folk use for that mirror finish on bare aluminum) with foam (for wax application) and terry or microfiber (for buffing) bonnets can speed and ease the process of waxing without any damage to the finish on modern Airstreams.
Do not use polishes or cleaning compounds (per Airstream recommendations) which are abrasives. Just plain wax.
GammaDog is offline   Reply With Quote
Old 08-16-2016, 02:52 PM   #7
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
I have a 2001 Safari I bought new. I use Meguairs Gold liquid wax and I apply it with a 10" Craftsman random orbiting polisher with the thin blue applicator pad made specifically for applying wax. Do not use the cotton fleece pad to apply or buff the wax. It will damage the clear coat. Wipe the dried wax off manually with an old soft towel. I wax once a year. I've done this for 15 years now and my AS still looks new. It's not the mirror finish of a highly polished vintage AS. It's the shiny clear coat finish of the newer Airstreams. I treat it like I treat my cars and truck which also have clear coat finishes. I get "it looks like new" comments every time we take our AS out.
Nomad518 is offline   Reply With Quote
Old 08-16-2016, 11:10 PM   #8
Much appreciated all. I will most likely try Griots One Step under the rock guards (most white blotches) with my Griots Random Orbital to test.
Old 08-17-2016, 11:14 AM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
if you want shiny- go vintage
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-17-2016, 11:50 AM   #10
2015 28' International
Ofallon , Missouri
Walkerize and a soft rag. Little elbow grease required.
mpsgolf is offline   Reply With Quote
Old 08-17-2016, 01:21 PM   #11
Boxite's Avatar
2008 22' Sport
It may be that a definition-of-terms be in order.
When I read "orbital polisher" ... I thought of a device to apply "polish" at high speed ...which will burn the clearcoat (a plasticizer type of synthetic covering used to fight oxidation on our modern Airstreams.)
If you only mean to "BUFF" using WAX... and don't "bear-down" and burn theclearcoating ... it should work fine.
But DON"T USE POLISH which has fine abrasive or defect-remover in it. You will ruin the clearcoat and injure it's purpose.
Rambox
Orbital Polisher Okiestreamer Airstream Classifieds 0 11-14-2015 01:47 PM
Random orbital instead of Cyclo? adwriter73 Cleaning, Stripping & Polishing 8 05-11-2014 05:52 PM
Porter Cable Orbital vs Cyclo Becky B. Cleaning, Stripping & Polishing 30 06-23-2013 08:14 PM
Question about the Porter Cable random orbital Eagle & Bear Cleaning, Stripping & Polishing 3 12-01-2012 07:08 AM
Random Electrical Discharge [A/S 325] Fish36991 General Motorhome Topics 27 02-11-2005 05:39 AM
