Originally Posted by redhawkerII
That did happen, the wind moved the tarp around enough for one day to rub litttle patterns of buffed places here and there. It would also be nice to build a 'standing roof'-whatever that is called. I even checked out other quick coverings like indoor outdoor turf. we have an upholsterer next door and was looking at some of his vinyl materials, and am thinking about getting a estimate from him....I know THAT material comes in huge rolls as big as carpet. Being a do-it-yourselfer I would just purchace a very large single piece of his stuff and use that. But I swear I will never ever use that blue tarp stuff again!
I have found that what causes the many marks and scratches, and I can see it in your picture is that 1) the tarp is not thick enough, 2) you only have it tied down by the loops. I have our 77 that is for sale sitting in my yard, it is covered with a 10 mil tarp 50X30, after placing the tarp over the trailer I took 3/4 in pvc pipe I had in the garage and ran it down each side of the tarp, rolled the pipe up in the tarp for 2 turns under put holes thru every 12 in and tied, this way I had tie down every 12 inch this allowed me to spread out the pull over the entire length to prevent ripping, the pvc pipe then secured with bunjie cords with a little more than 1/2 tension on the cord (almost enough tension to tear the tarp then back off, the tie down on the ends are with cloth clothes line and tied in X pattern. I then wrapped with the same type of cloths line starting where the end cap comes around on the side and went around and around (over top & under bottom) the full lenght of the trailer every 2-3 feet. Each end of the rope had a sinch loop and a bunjee cord to maintain tension. I have not had any movement from storms or wind off the mountain, there is some moisture from hot & cold but not as much as one would expect, this is taken care of by every 2 weeks loosen and wipe with a towel.
I now plan on getting some 3/4 pvc in 20 ft lengths and joining together then bend in an arc to fit over the camper where is not touching, with T's as spacers. Buy a Tarp like we use on Flat bes since they are padded and anti moisture for cover, this will keep it off the trailer and provide protection.
Sarge
