Old 01-03-2005, 09:46 AM   #1
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Protecting the wood trim during the stripping.
We have three whole months to worry about this problem and come up with a solution.
Our motor home has a perfect, not even a scratch on it, wood decal trim around the center. This is original and we want to keep it that way. This spring we will be stripping the clear coat to start polishing the problem will be how to protect this wonderful wood decal from getting stripped in the process. When I stripped our trailer I used a water based 3M stripper which was fairly tame but I am certain strong enough to remove this decal trim. Any one out there had any experience taping off decals from paint removers.
Thanks in advance.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 01-03-2005, 12:06 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used blue masking tape to hold heavy brown painters paper to protect some areas when I stripped the lower grey paint off my AS. It worked well. If you are going to get the area very wet though, not just a few drips, I would want to tape some heavy plastic over the paper to keep the moisture off. Also keep wet cloths nearby for the occassional missed drip that you can clean off quickly. I also used mineral spirits to stop the stripper action, then hosed everything off with water.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-03-2005, 12:07 PM   #3
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Duct tape?
I'm not sure that the stripper wouldn't soak through but you could test it somewhere other than on your AS.
You might try double layering the tape
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
wood walls in an A/S? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 26 03-10-2008 11:35 AM
year wood veneer changed to laminate? thx yukonsilver Interior Restoration Forum 4 04-18-2004 05:31 PM
Wood veneer type Silver Bullet Cabinets, Counter Tops & Furnishings 7 03-25-2004 06:46 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Stripping...Clearcoat that is! InsideOut Cleaning, Stripping & Polishing 19 07-12-2003 07:59 PM
