Old 08-19-2003, 03:49 PM   #15
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Thanks for the update.
Garry
Old 08-19-2003, 03:54 PM   #16
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Hey David ~
Thanks for following up on this...it's an interesting alternative. Did you ask about a solution to trapped air bubbles around the rivets? I still think they would create a problem with temperature changes and the coating would delaminate (or never attach properly) at the rivets...
Shari
Old 08-19-2003, 04:24 PM   #17
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Air around rivets
Shari,
There is no doubt that the area around the rivet will trap some air. After talking to them, I am interested to see if the adhesive is truely as agressive as they indicated. If it is, I don't think there will be a problem with the the adhesive releasing from the rivet area or allowing dirt/moisture into the area. I think I will have N Dallas RV rivet me up a row of olympia rivets thru 2 pieces of aluminum and shave the heads so that I can apply over them and get a better look as how the film pulls down into the dimple. Also remember that the rivet head is actually above the plane of the aluminum skin so there is only the area just around the edges of the rivet that might be an issue. During installation, there is a short lived barrier of moisture that allows the air to be worked to the edges. The rivets would be close to the edges, so air might not be that difficult to work away from the rivet area. As the film is worked from the center outward, the adhesive becomes more and more attached, so once air is expelled from a rivet area, I don't feel that the rivets will be a particularly problematic area. I do understand your concern over time. I will post the results of the test skin I will have made as well as how it actually applied and looks on the front of the Bambi.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 08-19-2003, 04:34 PM   #18
InsideOut's Avatar
1956 22' Safari
Images: 108
Cool...anxious to see the results of your test...
Shari
Old 08-19-2003, 05:07 PM   #19
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
One thing to remember is that the newer trailers have fewer rivets, and those that are there on the newer units seem to follow the panel edges moe than in past vintages. I would be curious as to the results where the rivets are mid panel.
I wonder if this stuff could help prolong the paint life on end caps of the Argosy line?
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-19-2003, 05:28 PM   #20
LOST , Hawaii
We don't have to worry about that, we have good old clear coat. The Argosys might not be as pretty and shiny but are more conventional to maintain (that is not what I was saying when I was washing that big old white thing this AM though.)
John
74Argosy24MH is offline   Reply With Quote
Old 08-19-2003, 08:16 PM   #21
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Should work on Argosy as well
As this same stuff is being used on car surfaces (extreme high end unit especially), I would think it would work on the painted surfaces of an Argosy.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
WBCCI # 7548
tow vehicle isolated from A/S batteries?? BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 13 02-05-2004 12:50 PM
A/S Wannabeeeeee!! Soon GT1963 Our Community 11 01-25-2004 01:48 PM
19' Bambi cork floor need sq. feet of A/S JimBrownUT Floor Finishes 4 01-07-2004 05:26 PM
Anbody have their A/S parked in Adairsville GA? 59toaster Our Community 0 02-20-2003 09:08 PM
