Old 05-29-2009, 04:58 PM   #1
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
Propane tank polishing
Well, it's another rainy day here in New England, I wonder if the sun is EVER gonna shine. So I thought I would put into action some of the advice that I have read on here and start polishing my tanks since we can't move the AS outside yet to strip the clearcoat.
I took both tanks to ABC gas and they replaced the valves and recertified them. Pick them up yesterday. Both are empty.
So, I started by building a cradle to hold them, just some 1x3's and some scrap plywood and a few sheet rock screws. Nothing fancy but works nicely.
So far I have only done the first step, I have wet sanded one with 220 wet, with a small palm sander It took me about an hour to get to where I'm at now. I don't think it's going to be a hard project, just time consuming. Tomorrow I'm going to jump up to 600 grit and see what happens. Then I'll go to the rubbing compounds.
So If there are any women out there. remember you too can polish with the best of them!
Annette
ID:	81129   Click image for larger version
bullydogsmom is offline   Reply With Quote
Old 05-29-2009, 05:13 PM   #2
Kevin245's Avatar
Smile
Keep it up Annette, and keep the photo updates coming.
Kevin
Eleanor Roosevelt
Old 05-29-2009, 07:39 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
My cradle is similar.but I had mine full that 30# sure helps when you put that big buffer on there.If you didn`t,you should screw your cradle down to the table.Dave
easyride is offline   Reply With Quote
Propane Tank Noise jrk247 LP Gas, Piping, Tanks & Regulators 20 01-16-2017 08:22 PM
Do you empty propane before polishing tanks? Becky B. Cleaning, Stripping & Polishing 20 08-30-2009 07:03 PM
Propane tank cover walter1 LP Gas, Piping, Tanks & Regulators 9 03-14-2007 11:08 PM
How full is the propane tank? BJo LP Gas, Piping, Tanks & Regulators 32 12-29-2004 09:49 AM
Propane tank charlief1317 Airstream Motorhome Forums 14 01-04-2003 08:00 PM
