Old 03-07-2006, 12:24 PM   #1
1954 22' Flying Cloud
austin , Texas
Project Polish Week 2
Well, I only got at it for about eight hours last week, but some progress was made after all
especially compared to a week ago
http://www.airforums.com/forum...ess-21042.html
Forcast is rain, so next week's might not be much of an improvement!
kitycatalina is offline   Reply With Quote
Old 03-07-2006, 12:40 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Looking good!
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-07-2006, 02:43 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Nice start!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-07-2006, 03:38 PM   #4
austin , Texas
Thanks!
I like how the pink flamingos are now reflected
Old 03-08-2006, 12:29 AM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Kity...
which grade Nuvite are you using to cut with? Are you using a buffing pad on a drill or.....? I can't tell if the haziness is leftover product, or if it just needs to be cut more. If it's leftover polish, I used flour on a t-shirt to get it off nicely.
Looking good!
Marc
Old 03-08-2006, 06:51 AM   #6
austin , Texas
I'm using the buffer from Harbor Freight that was eatred on the perfect polish site, and F7. I'll try the flour.
Old 03-08-2006, 06:55 AM   #7
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up 8hrs and...
Looking great~!
I think I spend 240 plus hrs on mine...lol
Just remember to use as little as possible for each spot and, keep it clean as you go..
There's a huge write up on it and, I'm sure you read up on all of it..
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 03-08-2006, 09:30 AM   #8
1975 Argosy 26
1963 24' Tradewind
Just a suggestion...
you may want to up your cutting power to G9. Your trailer looks very oxidized - you may cut some of your time and effort with it.
Keep it up!
Marc
Old 03-08-2006, 10:00 AM   #9
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Just a thought, this is what I did to cut the first layers fairly easy.
6 Buffer prior to using the Cyclo. Using a 3M compound to get at the first step of polishing.
Notes:
3M Super Duty Rubbing Compound 5954 Quart
+ Aggressive compound.
+ Remains wet on the job with little or no mess.
+ Maintains high rate of cut with constant pressure.
+ Buffs to high gloss with minimum of swirl marks.
+ Can be used by hand or machine.
www.balrgn.com
Old 03-08-2006, 10:20 AM   #10
Paul Mayeux's Avatar
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
Yeah, the G6 works well on really oxidized surfaces, and as it says on the perfectpolish site, it breaks down to something like C. I had to use it when I polished my Caravel because it was taking way too much effort and time with the F7. It also didn't leave as many deep cuts as the F7.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 03-08-2006, 11:24 AM   #11
austin , Texas
[quote=3Ms75Argosy]you may want to up your cutting power to G9. Your trailer looks very oxidized - you may cut some of your time and effort with it.
The top is way more oxidized than the top. In the back where I did a test polish, I got the same results with C grade. When I first brought her home, there was what looked like an abandoned polishing experiment on the side panel. As a necomer to this process, I'm a bit hesitant to use the G9 with the scratch potential.
When we're on the subject, here's something I've been mulling. I like the shiny look, without the so called mirror finish. Call it a "vintage" finish if you will. Shiny, but not sparkling bright. There are a lot of dents and such on her that I think are just showcased more as the finish gets brighter and more reflective. From what I understand the S grade is not only a tool for reaching the mirror finish, but will add some protection. If I'm not looking to reach that stage, will I need some some sort of protection layer? Should I use the S anyway, just lightly for the protective qualities? Or am I just all wrong?
I realize this is very much a work in progress, but there is much satifaction in just removing the corroded gunk on the first step. I'm sure the satisfaction wears off a bit as fatigue sets in!
Old 03-08-2006, 11:38 AM   #12
austin , Texas
ciao
53FC
Yeah, just a little light reading!
There is a big difference in too much/not enough polish. I guess it's just like goldilocks, finding what works just right. I think I may have figured the right amount out now.
Keeping a clean surface is a major part too. I've been using mineral spirts in a spray bottle for keeping rivets and such clean and tidy.
If the weather stays crummy, I may move inside for a bit. Got some nasty paint to scrape.
Thanks to everyone for the input!
Old 03-08-2006, 12:11 PM   #13
1984 29' Sovereign
Savannah , Missouri
Actually it's quite easy..put a il dab from your finger tip into a small square spread abt 2 in or so.. Picture a 2 in sq and just a dab in each corner of the sq..Work it together using the compound polisher...try it..
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 03-08-2006, 12:45 PM   #14
austin , Texas
ciao
53FC
Yep, that's about what I've been doing. Less is more.
Best Polish to restore Airstream ?? bgow 1969 Overlander 2 07-30-2009 11:04 AM
Old polishers take note Bradjun1 Cleaning, Stripping & Polishing 3 06-08-2005 04:06 AM
Focus Group to Meet next week -- are you IN??? Mr Jody Hudson Our Community 8 07-29-2002 07:35 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
