Old 01-14-2007, 09:43 AM   #1
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Primer removal
I've searched for any info on this with no luck.I posted a photo of what I'm almost sure is primer,I can see a few runs and flakes.Does anyone Know of a product that will remove primer and not clearcoat.I dont have any idea why this was done other than mabey some clearcoat blistering as it does get hot .there has been no repair.mabey enamel reducer.
ID:	30766   Click image for larger version
bertro is offline   Reply With Quote
Old 01-14-2007, 04:02 PM   #2
Your Airstream is 36 years old.
Unless the clear coat has been replaced, it died about 30 years ago.
Anything that will remove the primer, which is paint, will also remove the clear coat, which is another kind of paint, or at least what may be left of it.
You might consider refinishing the entire trailer.
Old 01-14-2007, 05:03 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Proceed with caution
... Does anyone Know of a product that will remove primer and not clearcoat.I dont have any idea why this was done other than mabey some clearcoat blistering as it does get hot ...
Primer and clearcoat, while different, have a chemical composition that requires strong chemicals to remove them. The only way one can be removed without damaging the other is through careful masking and chemical application. So I think you are hosed as far as a wunder-stripper is concerned.
As far as why someone primed that area, it is possible that the furnace failed and started blowing flames out the exhaust port. The intense heat may have ended up mottling the aluminum. The furnace port on my 40 year old Overlander shows no heat effects.
Until you are ready to polish your Airstream, you may want to leave the primed area as-is; the aluminum the primer is covering might not look too good.
Tom
Old 01-14-2007, 05:25 PM   #4
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Thanks,I'll leave well enough alone and refinish someday.
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 02:48 PM
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 02:34 PM
Window Removal Rob Windows & Screens 2 08-31-2002 08:49 PM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 12:56 PM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 03:22 PM
