Old 04-29-2005, 12:42 PM   #1
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Pressure Wash to Remove Clearcoat?
Hello Folks,
There is very little clearcoat left on both the top and sides of our Airstream and I'm thinking of trying to remove it just by using a pressure washer. Anyone else try this? Are we asking for trouble (leaks)?
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 04-29-2005, 01:13 PM   #2
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
From what I've been warned, it's not advised to pressure wash. It might blow out sealer from joints that otherwise wouldn't leak. However, I have used a regular garden sprayer to identify leaks and know several folks who will do that for regular cleaning. It's the lower magnitude of pressure that counts, I think.
Mary
Our Airstream adventure continues!
Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Old 04-29-2005, 01:35 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by myboyburt
Hello Folks,
Unless your using some kind of stripper the pressure washer will only reemove the loose stuff, and as Mary says, you'll be asking for leaks..
I'm currently stripping mine, using Por Stripper, spray it on scrape it off, then wash it down with water and scotch brite pad. Don't it figure it's TOO sunny out to do the west facing side!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-30-2005, 05:41 PM   #4
myboyburt's Avatar
1993 25' Excella
Images: 12
Ok! Won't try this
We will use stripper instead of a pressure washer. Thanks for the feedback!
Michelle & Leon
New England Unit
Old 04-30-2005, 07:07 PM   #5
fun stripping in the sun
Well I definitly wont strip the clearcoat in the sun again hehehe... The first coat dried real fast so I figured I would coat it again. When I brushed it on.. In instantly started to boil. Ended using paint thinner to get it off then paint thinner and .0000 steel wool. then when I put some polish on that area the alunimum burned my finger.. It wasnt even that hot out. Ive kept reading here about not polishing in the sun BUT im almost done with the compounding part and to be honest i cant wait hehehehe... I look like rudolf the red nosed reindeer... Went in and put some sunblock #50 on...
Amazing to see the transformation from dull to shiney.. The more I do the more neighbors ive never met come and check it out..
Ed Starman is offline   Reply With Quote
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
Washing/waxing "new" clearcoat Kistler 2002 - 2005 International 13 11-21-2002 09:27 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
fuel pressure PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
