05-11-2011, 04:13 AM
1976 27' Overlander
Rosendale
, New York
Pressure wash??
Just pressure washed my girl
" Liz Trailer " and it went surprisingly well.
05-11-2011, 07:03 AM
1999 23' Safari
Perrysburg
, Ann Arbor
I do mine from time to time, as despite what the "pros" tell you, if you don't get too close and don't aim into vents, gaskets, etc. it can get a lot of the "grunge" off without getting you into much trouble.
Having said that, I still get a much better job with a bucket of warm soapy and a rag and brush or two and a chamois.
05-11-2011, 07:26 AM
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
... pressure washing often causes more problems than it solves. I would recommend avoiding using water under pressure.
If you insist on using a pressure washer, remove the grime using a rag or brush and "rinse" the trailer with a mist only keeping the wand a long way from the panels.
If you are using water pressure to remove dirt & grime, you are likely compromising the sealant between the aluminum panels and around the window frames.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
05-11-2011, 07:33 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We use pressure washers on Lucy quite often. Lucy spends a lot of time on the road, and coin-op car washes are about the only choice when she needs a bath. We do use a soapy brush first and keep a little distance with the high pressure rinse. We have not experienced any wash related problems.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
05-11-2011, 07:46 AM
Corona
Pressure washing does a great job removing older plasticoat.
05-11-2011, 08:10 AM
2012 25' Flying Cloud
Battle Lake
I wouldn't do it. Great possibility of water intrusion you may not know about until the floor gets soft.
Doug
05-11-2011, 08:39 AM
2010 25' FB Flying Cloud
Davenport
, Iowa
Now that you have it clean, what brand of wax/polish do you use? I understand thatg one should NOT use one with a cleaner, but Walbanize says it has cleaners ????
05-11-2011, 08:28 PM
1976 27' Overlander
Rosendale
, New York
Ok first off I should have mentioned that we have bad water pressure to start with and the machine is%
05-11-2011, 08:31 PM
1976 27' Overlander
Rosendale
, New York
Ok first off I should have mentioned that we have bad water pressure to start with and the machine is a crappy piece of ---- with like no power so I think the only thing I'm at risk of damaging is my is my.... Lol. Any way the floors ah too late lol! As you can see it cleaned off dirt and mold!! She sat for 8 yrs and still look not to bad but leaking in interior from some opening caused damage and the mice made it dirty and stinky!!! Now she's very clean and no leaks yet. One thing other then opinions I'd like would be you experts common over to polish her lol! I will help you polish your if you help me polish mine!! He he!!
But seriously it would be cool to find someone close and work together on our streams. Help and share!
11-26-2011, 08:23 AM
1976 27' Overlander
Rosendale
, New York
It's funny how a thread drops dead like this lol!
11-26-2011, 08:25 AM
1976 27' Overlander
Rosendale
, New York
Water damage?? I think the pressure washer is ok
11-26-2011, 10:35 AM
Battle Lake
Water will surely be forced inside the shell between the walls.
doug k
11-26-2011, 12:35 PM
Maniacal Engineer
Lopez Island
We use a long extension handle that carries water to a soft brush - this works really well. Our pressure washer is pretty wimpy, and the brush actually does a better job - and I don't worry about forcing water places it doesn't belong if I get too close with the pressure washer.
- Bart
