Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 03-29-2007, 12:04 PM   #1
happydaze
Profile:  1970 31' Sovereign
palm springs , California
pool acid to strip trailer?
Hey guys
Has anybody used pool acid to strip your trailer...We had an automotive guy tell us to put some in a spray bottle with water and just do section by section...he says it gets everything off...Removeall didn't work that well on ours...Whadda ya think?
happydaze is offline   Reply With Quote
Old 03-29-2007, 12:06 PM   #2
markdoane
Profile:  , Minnesota
Images: 59
It works great on my fiberglass boat, but I don't think I would use it on a trailer.
Non-contributing deadbeat.
Old 03-29-2007, 12:11 PM   #3
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Corrosion...
While pool guy might be correct for cleaning small sheet of aluminum, and with proper rinse and neutralizing of muriatic acid, any molecules of acid remaining on an Airstream around a joint or rivet head would be the starting point for corrosion... That corrosion would happily eat away at the skin leaving shiny metal replaced by white powder...
Even though mild acids are used to treat aluminum skins as part of anodizing processes, and other treatments, I wouldn't risk it... There are aircraft paint removers that will remove the surface coatings better and more safely...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 03-29-2007, 12:41 PM   #4
happydaze
do you know what kind of aircraft paint removers to get? and where? I guess the acid is not working
Old 03-29-2007, 01:03 PM   #5
Condoluminum
Use the "search" tab..
If you type "aircraft paint stripper" into search tab above, you'll find a series of threads on the subject... Several of the brands mentioned there include "Kleen-Strip Aircraft stripper" and "Removall 220 Paint Remover". There are also suggestoins to contact Vintage Trailer Supply or professional paint stores for suggestions..
Do beware that any stripper is going to attack plastics or other soft parts, so they should be removed/covered-taped over before applying stripper. You should also have plan for flushing away residues in envirnmentally acceptable manner as part of process, since they are messy...
Condoluminum
Old 03-30-2007, 02:17 PM   #6
nickcrowhurst
Profile:
I've always found "Aicraft Paint Stripper" (Yes, it's branded as such) at Wal-Marts near the automotive spray paint section. It works well on the Airstream clearcote.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-01-2007, 02:38 PM   #7
Haoleman
Profile:  Currently Looking...
Lanesboro , Minnesota
Pool Acid!!!
Tell the guy that told you to use pool acid that it completely stripped the skin off the trailer!!! This is fine if you want lots of ventilation and a skeleton.
That's almost as bad as pissing on an old American mag wheel!
Good aircraft paint stripper should work fine or go to a place that sells automotive paints and get some stripper designed to remove basecoat-clearcoat finishes. I did my old 86 T bird with the stuff and it was slick.
took only 20 minutes to strip the whole top, trunk lid and hood.
Haoleman is offline   Reply With Quote
Old 07-01-2007, 05:21 PM   #8
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Rivet Pool Acid
As I recall, muriatic acid (HCl http://en.wikipedia.org/wiki/Hydrochloric_acid) was promoted by Hot Rod and other car mags for removing rust from steel bodywork and cast iron parts. I don't think anyone then (or now) reccomends using it on al.
Vaughan
Old 07-01-2007, 05:46 PM   #9
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Hey guys
If you want to ruin your trailer, put acid on it.
Putting acid on the shell will also create water leaks around almost "every" rivet.
DON'T DO IT!!!!!!!!!!!!!!!!!!!!!!!!!!
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 19 12-12-2003 07:39 AM
Suggestion: Airstream trailer Forums (by Model & Year) hex Forum How-To's & Support 2 10-15-2002 06:38 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Lookin for answers-picking up newly acquired trailer COArgosy78 Our Community 2 09-02-2002 01:23 PM
Trailer Life RV Campground Finder Pahaska Our Community 12 08-03-2002 08:45 AM
