Old 06-03-2016, 08:05 PM   #1
OklaOverland's Avatar
Tulsa , Oklahoma
Polishing Woes
Name:	ImageUploadedByAirstream Forums1465005631.494776.jpg
Name:	ImageUploadedByAirstream Forums1465005653.285416.jpg
I thought I was done polishing one side of my airstream but I have these swirl marks EVERYWHERE! I'm super afraid that I burned through the alclad but I'm super hoping you guys say no and know how to fix this. I noticed it when I was using F9 but thought it would go away when I went to C. I don't know if I pushed to hard or used the wrong amount of polish but I'm hoping it's not permanent. I'm following the method that Hoffarc suggests but maybe I need more passes of Grade C. He only does one before going to the cycle so that's what I did. Should I have done F7 between F9 and C or did I just need to do C until these are gone and then go to the cyclo with S? Any help is greatly appreciated.
See my progress on Instagram @MonicaTheAirstream
OklaOverland is offline   Reply With Quote
Old 06-03-2016, 09:38 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
F9 to C is a big jump. I'd try to go to G with a wool pad, then to the C if needed. Finish with S and the Cycle. It does not look like a catastrophe to me.
Old 06-05-2016, 08:44 AM   #3
Tulsa , Oklahoma
Thank you. I ordered some G6. Fingers crossed.
Polishing woes, can you help?? 68tradewind Cleaning, Stripping & Polishing 2 08-08-2010 08:57 PM
THEM DOGGONE SWIRL MARKS! And other polishing woes. millionairstream Cleaning, Stripping & Polishing 6 06-16-2006 10:20 AM
Water Heater Woes airstreamcaravel Water Heaters, Filters & Pumps 3 09-07-2005 09:18 PM
Armstrong A/C Woes on 71Sovereign MikeT Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-14-2002 12:09 PM
