Old 11-19-2010, 01:58 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Polishing with Nuvite-S
I'm about to start the final phase of polishing my Sovereign. I've never used a cyclo before. What is the best way to go about polishing with the cylco? Should I use the cotton terry cloth pad covers like VTS sells?
Cyclo Cotton Terry
or should I use old sweatshirts/cotton fabric? I'm just not sure which is the best, most preferred method to acheive a mirror shine. I hear the terry cloth pad covers leave minute scratches in the surface. Is this true?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 11-19-2010, 02:47 PM   #2
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I use the sweatshirt material from perfect polish! Polishing Cloth
Try both if in doubt! Lots of opinions on polishing!
Paul
Troy Mi
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 11-19-2010, 03:05 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used old sweatshirts from goodwill
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-19-2010, 03:40 PM   #4
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
I tried both and had mixed results. If you use the terry clothes from VTS order a lot of them. They go very quick and when they get caked they are garbage. You cant wash them out like the large ones. I would recommend trying both and see what works for you. The cyclone took a lot longer then I had expected and a lot more work than the drill with a 6" pad. But you can get rid of all those swirl marks and the job looks a lot better.
Good luck
nick6930 is offline   Reply With Quote
Old 11-19-2010, 04:25 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Mike....If your starting the polish job you will need to use stronger medicine than "S"....It all depends on the condition of the starting point. Have fun..
Old 11-19-2010, 04:34 PM   #6
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I used the sweatshirt material from Perfect Polish too. You can wash them & use them more than once.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-19-2010, 05:03 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Mike,
I bought my material at a discount store in Phoenix. There is one located just south of Peoria on 19th Ave. I then cut them to the size shown on the Perfect Polish site. They work very well at a fraction of the cost.
Richard
Old 11-19-2010, 05:29 PM   #8
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Just make sure they are 100% cotton (no polyester) or they will scratch. We bought the ones from Perfect Polish and they have lasted through two trailers. We also use micro-fibre cloths to remove all the residue as a "final pass".
Shari
Old 11-19-2010, 05:47 PM   #9
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Hi Mike,
At the Resto Rally Levon did a demo using cotton rags he bought at Target or W Mart.
They we in a box of random sizes with most being large enough to wrap and hold by hand ,rotate to clean an toss.Check with him,although I haven't seen him post in awhile.He has polished 13 or so trailers with bar method and finishing with Nuvite and cyclo.I am sure he has tried everything at this point.Steve
bwaysteve is offline   Reply With Quote
Old 11-19-2010, 06:23 PM   #10
Jezibels's Avatar
1966 24' Tradewind
Chicago , Illinois
I tried sweatshirts and flannel sheets, and the terry cloth pads from VTS. I liked the terry cloth pads, but you must buy the yellow sponge pads to go under them - over the cyclo heads, also thru VTS. No worries when they get caked, put them in a tub and let them soak with soap and water. Rub them together and rinse them out, let them air dry then re-use. To refresh polish I use the F7 then the S.
Happy Trails!
Jezibels is offline   Reply With Quote
Old 11-19-2010, 10:12 PM   #11
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by azflycaster View Post
Mike,
Richard,
Do you have the name of that store?
Thanks for the replys, everyone. I'm going to try both and see which one works best for me.
1958 Overlander
4CU 1st VP
Old 11-21-2010, 09:32 PM   #12
Not sure if this was already mentioned but we went to a fabric store and bought 100% cotton remnents. They were a hideous yellow/brown color but worked great and cheap. We also followed the Perfect Polish sizing of material, cut the holes in the corners to put over the Cyclo handle and held the bunched fabric on the Cyclo which was fairly easy to handle.
Old 11-22-2010, 09:17 AM   #13
Levon's Avatar
1985 27' Sovereign
1981 22' Excella II
Colbert , Georgia
Images: 168
Cotton Rags
Greetings Mike,
I use a box of painters rags (100% cotton) that I bought at Lowes. They come in 10# boxes (approx. $20), most can be used with the cyclo, the ones that are too small are used for cleaning the rivets and other areas. 10# box will do a 20' trailer. When finished just toss....I tried the washing and reusing of cyclo polishing rags but after my wife ASKED me to clean the washing machine (2 hrs spent)....I just toss them away now.
Good luck with your project.
If you have time, visit my website:
Airstreams - Southern Antique
to view some of our past projects.
Best Regards,
Levon
Levon is offline   Reply With Quote
Old 11-22-2010, 09:56 AM   #14
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by Levon View Post
Greetings Mike,
Thanks Levon. I remember you talking about using the 100% cotton rags at the Restoration Rally but didn't remember where you got them. I don't remember, but did you fold these rags over and clamp them in the back or did you just lay the cloth flat and start polishing?
1958 Overlander
4CU 1st VP
how much nuvite? ssfletch Cleaning, Stripping & Polishing 3 04-02-2010 01:55 PM
Nuvite, How Much The Flintstones Cleaning, Stripping & Polishing 31 08-06-2007 02:32 PM
rolite vs nuvite nevisstudio Cleaning, Stripping & Polishing 1 08-01-2005 04:47 PM
Walbernize/Nuvite??? tmeagle1 Cleaning, Stripping & Polishing 3 01-11-2004 06:24 PM
