Old 12-17-2012, 10:03 AM   #1
Airstream Newbie
rv4007's Avatar
1978 31' Sovereign
Covington , Louisiana
Polishing with Buffpro and Nuvite
After trying various methods of polishing, I found one that works for me. I tried circular buffers, dual-action orbitals, automotive compounds, Mojo, Purple Metal Polish, Truck Box, etc.
I thought I would pass it on a video of Buffpro and Nuvite A which works well to get to the level of finish I am looking for. I am not looking for show quality, just impressive.
I will still use some of the other products for certain tasks, but the Buffpro/Nuvite seems to get the bulk of the work done quickly. For instance, I like the Mojo metal polish for hand polishing while on the road.
I am also considering purchasing a cyclo to see if it provides any additional benefit, but I am pretty satisfied with the current finish.
It is always a tradeoff between effort and finish. If I lived out west where the humidity is low, I would go for a perfect mirror finish, but I live in south Louisiana, so I think I will settle for something less as I don't want to polish everyday of my life!!
Take a look at my video on youtube to see how it works.
PS. I didn't show it on the video, but after I apply Nuvite to 2 or 3 sections, the drum starts to load up. At that point instead of using a rake on the drum, and wasting the Nuvite, I just mist some mineral spirits both on the next panel to be polished and on the drum which allows the Nuvite to flow out of the drum so that it is not wasted.
Dennis & Denise Thomas
1978 31' Sovereign
2006 Hummer H2
Hensley
rv4007 is offline   Reply With Quote
Old 12-17-2012, 11:09 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Polishing for Ev'ry'Streamer -- interesting technique & excellent comments. Thanks Dennis.
5 meter Langford Nahanni
Old 12-17-2012, 11:39 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Thanks!
Old 07-26-2013, 08:25 PM   #4
Marietta , Georgia
Based on your video, I bought the Buffpro and I'm using the Nuvite A and not getting any near the same results. I guess my question is what pad are you using? Mine came with the finishing pad but I see online that they have various cutting grades. I was thinking of getting the wool one but before I did, I wanted to know what you used for this demonstration.
ArtWithin is offline   Reply With Quote
Old 08-05-2013, 04:34 PM   #5
Airstream Newbie
rv4007's Avatar
1978 31' Sovereign
Sorry for the delay. I am using the wool pad. You will need a rake for cleaning. Jesco has one
1978 31' Sovereign
2006 Hummer H2
Hensley
Old 09-29-2013, 12:43 PM   #6
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
Wow, thanks for posting this and the video too. I just saw this polisher on a car tv show and immediately thought it might work well for an airstream. Came looking to see if others had used it and your post was very helpful.
Looks like these units are not cheap but the savings in effort is well worth it. The manufacturer says that this unit does not leave swirls because of the drum design. Also just to note for others, the specs say it runs up to 2500 RPM but the maker says that they usually run it at 2000 (car use on paint).
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Old 09-29-2013, 12:57 PM   #7
CA_Tallguy's Avatar
Zavalla , Texas
Just went searching for similar products and found this company that claims to have the air powered drum buffer developed for American Airlines. Not cheap. They also have a lot of airstream related products and services.
Airmark Surfacing Tools - providing aluminum polishing, buffing wheels, air craft polish, boat polish and much more.
WBCCI #1711
Old 10-18-2014, 05:09 PM   #8
Brooklyn , New York
Just viewed the video also. Has anyone got any update on the performance of the BuffPro versus using the a dewalt rotary tool? Looks fantastic from the video, but just wondering if anyone else has tried it recently on a moderately oxidized airstream? Thanks.
Trady66 is offline   Reply With Quote
Old 03-24-2015, 06:42 AM   #9
1968 28' Ambassador
Warwick , New York
I'm about to pull the trigger on buying a polisher and this looks fantastic. I have two airstreams that need to be polished buy May 1st and this looks like quite a time saver. Anybody else have any experience with the buffpro? This will be my first time polishing anything.
hedgerocks is offline   Reply With Quote
Old 03-24-2015, 10:36 PM   #10
CA_Tallguy's Avatar
Zavalla , Texas
I believe all the professional airsteam polisher folks use the drum type, however many may use the aircraft type that is air driven -- but they require a huge air compressor. So huge that they are cost prohibitive for most casual DIY folks. I didn't realize how hard it was to get an air compressor that blew a lot of air (CFM) until researching for this purpose.
WBCCI #1711
Old 03-25-2015, 07:09 AM   #11
Marietta , Georgia
Buff pro results
I used the buff pro and had mixed results. You have to get the right pad. I made the mistake of getting the pad that was more of a finishing pad first and then had to buy another one. The good- it does not leave the swirling pattern and it covers more area. The bad is that I haven't found it to polish as deeply as I needed. It's a great tool after you've polished to keep your polish in my opinion.
Old 03-25-2015, 12:37 PM   #12
1968 28' Ambassador
Warwick , New York
Basically I'm about to make an investment in buying tools and polish for this project. (need to polish to 1967 27ft airstreams)
The Dewalt is significantly cheaper. But things start to add up. Buffpro has "the metal polishing kit" which seems to provide everything (3 types of nuvite and three different buffers). Its very tempting. I'm defiantly not looking for the "best" shine. Just an upgrade from its current state. Do you have buyers remorse? Did it save you time?
Old 03-26-2015, 12:04 PM   #13
Marietta , Georgia
Buff pro
I don't have buyers regret. I would still buy you a cheap circular buffer from Harbor Freight just in case.
Old 04-26-2015, 06:10 AM   #14
1967 22' Safari
Space Coast , Florida
Hello Dennis, I am considering the Buff Pro and saw your video. We have a 1967 Safari which had been polished previously. The shine is dulling and I was considering paying someone to re-polish it. Did you use nuvite A? And would you recommend the buff pro. I am not worried about show quality either as I live in Florida and store it outside.
thanks, Sam. 321-794-5959
SamIam427 is offline   Reply With Quote
