Old 01-14-2005, 08:31 AM   #1
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
Polishing update
For those who have stripped and polished their units I wish to share something I have found.
I live w/i 8 miles of the Atlantic in Palm Bay Florida.
I originally stripped and polished my unit in Jan 2003. That took 200 hours of work using Kleen Strip Aircraft stripper, compounding with Nuvite "C" then polishing with Nuvite "C" and "S" The polishing was done with the Cyclo polisher.
I did the second polishing Jan 2004. I polished with Nuvite "C" and "S". That took about 30 hours.
I am doing it again now, Jan 2005. For some reason, the aluminum is more oxidized than last year and I had to compound with "C" then polish with "C" and "S".
About 1/4 of the way through, I was getting frustrated with the amount of time, work and polish it was taking. As one of the things I tried, to cut down on the amount of work, was to compound with "S". Now this is not supposed to work because "S" doesn't have the grit that "C" does. But to my great suprise it worked to perfection.
Vigorously Compounding with "S" leaves the finish in a near mirror finish with virtually no swirling. The finish gets covered with the black messy aluminum oxide. I don't compound until it goes away. I wipe with a piece of sweatshirt material and then polish with the Cyclo/sweatshirt combo. The outcome is near mirror. If there is any hint of oxidation left I either recompound or just polish by hand using a daub of polish and a microfiber towel. Then polish again with the Cyclo.
Using the "S" and the compounder leaves NO VISIBLE SWIRLS! I don't know why this works but it does. The work goes faster because I don't have to deal with the swirls left by compounding with "C".
As a finishing touch, I wash the polished area with Mineral Spirits to remove any residual aluminum oxide, then I put on a coating of Liquid Glass and polish it off with the Microfiber towel.
I got the Microfiber towels from perfectpolish.com along with all my other polishing needs. The towels WILL NOT SCRATCH no matter how hard you rub the finish. This is amazing because one of the problems of washing and waxing was the scratching of the finish that occurred. The towels have solved that problem.
Also I have purchased the Mr. Clean car washing system and I use it on the trailer to remove water spotting from rain. The Liquid Glass seems to facilitate the removal of the spotting. Washing with the Mr. Clean and using the Microfiber towel to wash then rinse with the Mr.Clean leaves no spotting. There may be some almost invisible streaking from the Mr. Clean but a quick wipe with the towel eliminates that.
I know this all sounds like a lot of work, but if you polish, you commit yourself to keeping the finish presentable. It is part of the pride of ownership.
There are as many methods as there are people who polish. For maintenance polishing, I think I have hit on a good method.
Vic Smith
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
http://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 01-14-2005, 09:30 AM   #2
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Sounds like you've struck on a nice method! I'll come back to this thread when I get to that stage, and try it out on mine. Thanks for posting it!
bredlo is offline   Reply With Quote
Old 01-14-2005, 10:40 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
How is the Liquid Glass holding up for you? I find it lasts a really long time.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-14-2005, 10:44 AM   #4
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Vic
Good to hear from you - S does contain a little grit - when I do my annual update polishing, thats all I've ever used - I agree - it works great.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 01-15-2005, 01:25 AM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thanks for the tip...
I'M PRINTING THIS...as I expect to be reunited with my unit very shortly...
I also keep mine within 2 miles of the ocean in Va.
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 01-16-2005, 09:37 AM   #6
Palm Bay , Florida
Images: 34
Alan,
I did a test area in two places on the unit last year. The first was under the front window and the second was between the door and the kitchen window. Both areas seemed to retain their lustre longer and were easier to clean. Additionally, I had used Mothers aluminum wax which was fine except it put a haze on the finish that dulled the shine a little. The Liquid Glass is well... like glass. No haze or discoloration. That's the reason I decided to use it on the whole unit. The Liquid Glass is a bit pricey at $16.00 a pint, but it works so well then I consider it a good buy.
Vic
Vic Smith
WBCCI #6782
Old 01-16-2005, 05:35 PM   #7
Silver Bullet's Avatar
I Love it!!!!!
A product that I have used for the past 25 yrs. comes to realization! Originally it was called "Nautical Glass". Designed for boats in the water, (in my case "fresh water") to help keep the boats looking good top side and the grunge from adhearing to the bottom. Use it, you will not be disappointed.
Oscar
Silver Bullet is offline   Reply With Quote
Old 02-02-2005, 09:23 PM   #8
stripper??
We just purchased a 1978 Sovereign. Lots of the clearcote is gone leaving a blotching, dull surface. I've read that there is a stripper by Napier that can be purchased @ Sherwin Wms. Any suggestions. With 31' of trailer, I hope we can get it right the first time. Thx. Windyg
windyg is offline   Reply With Quote
Old 02-03-2005, 08:27 AM   #9
Palm Bay , Florida
Images: 34
Windyg
I have not tried Napier but I suspect that it isn't as strong as Aircraft Stripper. I have used a Klean Strip stripper from Wal-Mart that was not as strong and did not do the job as quickly and cleanly. I tried Citristrip and it was a miserable failure. The Klean Strip Aircraft Stripper is what professional automotive painters use. It is toxic and needs to used with care. Don't get it on plastic, vinylclad or glass. I put it on with a brush and used a plastic scraper to gently lift off the residue. Keep a hose handy. You will know immediately if you get some on your skin. Water will clean it off quickly. The positive side is that you only have to strip once. Polishing, however, is forever.
I got the Aircraft Stripper from an automotive paint store. In Melbourne Fla it is Finishmasters. I don't know if that is a national company.
Vic
Vic Smith
WBCCI #6782
Old 02-03-2005, 11:34 AM   #10
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
The Napier surprised me! I've had wooden boats for many years and was accustomed to using the Aircraft stripper and the JABSCO paint/epoxy stripper. When we had the Overlander I tried a section with both and neither one really attacked the old clear coat. I too tried the citri strip and the only thing it might have removed was dirt. I ordered the Napier and applied it with a airless paint sprayer on a cloudy damp but warm day and after about 20 minutes of sitting the old clear coat came off with a power sprayer like big blue pieces of snot. I don't know how it works but it does. The ambient temp does need to be in the upper 70s or 80s in order for it to work the best (according to the AS owner that told me about it) I've got two gallons waiting until the weather warms up to do our Caravel.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 02-03-2005, 11:39 AM   #11
1954 25' Cruiser
Paradise , Texas
By the way...
I tried to find the Napier at the local paint store and they said they would have to order it. I bought it from http://www.aircraftspruce.com/ and it was called 13-01515 NAPIER STRIPPER SV-35PMA GALN $55.850. It took 3 gallons to do the Overlander.
Paul Mayeux
AirForums #1565
WBCCI #7162
Old 02-05-2005, 11:28 AM   #12
stripper (remember we're talking Airstreams)
I really appreciate the insights regarding which stripper to use. I'd heard about the Kleen Strip, but when I looked further there was a $19 haz mat charge on an order. That stopped me as we'll be doing this in our gravel driveway & we live in a wildlife/dog/grandchild area. The Napier products are environmentally safe and can be cleaned off with a hose. Sounds good for us. Now the question is - our trailer is 31'. Do you think 3 gallons will do it? Don't imagine we'll have another use for the excess once it's done. Thanks again. You folks are terrific.
Windyg
Old 02-05-2005, 12:14 PM   #13
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
ICI sells it
If there is a ICI distributer by you, Napier sells the product under their "Hydrostrip" label at ICI. Apparently the Napier product works with peroxide to lift the paint. I hope to use it this summer on my Argosy and will post results later (much later, I'm in the Northwest! )
Marc
Old 02-06-2005, 08:38 PM   #14
Palm Bay , Florida
Images: 34
Oscar
Oscar,
The Liquid Glass works great for me too. I checked the underside of the Excella and not one barnacle could be found.
Vic
Vic Smith
WBCCI #6782
Polishing...approx cost? Drew Cleaning, Stripping & Polishing 10 03-31-2014 10:37 PM
Polishing Again davidz71 Cleaning, Stripping & Polishing 16 11-17-2005 05:40 PM
What Type of Polishing Pad to Use? 68 Suburban Cleaning, Stripping & Polishing 0 10-22-2002 02:28 PM
Anyone else polishing? 64GT Cleaning, Stripping & Polishing 24 08-08-2002 09:19 AM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
