Old 06-23-2006, 11:37 AM   #1
Polishing Tool Comparison- What Works Best?
Lets use the power of the vast members here to try and discover which polishing method, using which tools, and products will really work best.
Lets forget the fact that the "proven" method has been established by those who have "done it"- and anyone who is interested, check out info, trial and error, and measure up in time and quality which way can actually get results that we can be proud of- and hopefully with more weekends free for camping.
I'm suggesting that the barrel/drum polishing systems are affordable, easy, damage free- and WAY less time.
Spec Distribution- aircraftpolish.com Contact- Paul.
A&H Machine- airmarktools.net Contact- Brian.
Cyclo- perfectpolish.com Contact- Tom
I also know from experience, that using a variable speed buffer with a variety of coarse, soft, and finishing pads and the proper polish with each pad- will produce equal results in less time that one of the methods above.
Lets see what the masses say after doing research into the various methods and tools. This thread should not be utilized by those who like to pick at us who have an open mind and search for better/faster systems.
I'm also convinced that the expense of advanced polishing systems, when related to the costs of $125-$150 per foot, and the value of our trailers- which has skyrocketed in the past few years, is unwarranted to owners of classic Airstream and other aluminum aircraft trailers.
Let the fun begin!
millionairstream is offline   Reply With Quote
Old 06-23-2006, 01:42 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Drum polisher info
Compressor rental for a towable Diesel powered compressor is $ 95.00 a day, without fuel and accessories. It's more powerful than what is needed, but nothing smaller is available in my area. ( 185cfm)
There's some info attached in a .PDF which I already posted on another thread.
Apparently there are several sizes of the drum polishers available, from about $ 600.00 on. It allegedly takes 1/3 of the time with a drum polisher to polish a panel to high gloss, with no need for using a cyclo to take out swirls.
I am looking deeply into this right now, to get as much input from professionals as possible. Stay tuned..
Uwe
www.area63productions.com
Old 06-23-2006, 03:12 PM   #3
1965 17' Caravel
Vallejo , California
perfect polish
I just finished using the method/equipment recommended by perfect polish and vintage trailer supply (compounding first, then using the cyclo to remove the swirl marks) I am happy with the result. I probably should have spent more time compounding to get rid of all the filiform corrosion that had started under the old clear-coat. I used the Nuvite line of products (F7, a little G6, C and S)
I bought supplies from both Vintage Trailer Supply and Perfect Polish, both had excellent service.
At first I starting keep track of how many hours I was spending, but later gave up, as it got kind of depressing
Stan Z is offline   Reply With Quote
Old 06-23-2006, 03:39 PM   #4
Stan- What would you estimate the hours to be?
Old 06-23-2006, 03:48 PM   #5
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
I am doing the same thing, same sources, pretty much. So far there's approximately 100 hours in the polish job, with about 30-50 more to go.
Uwe
Old 06-23-2006, 06:36 PM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
don't you all think this topic has been beat to death already? Whatever method works for the "polishee" is the best.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-23-2006, 07:08 PM   #7
canton , tx
I hope this thread gets somewhere. Polishing is the last thing on my restoration agenda and I hope to learn some new ideas. Don't want a mirror shine and don't want to spend hundreds of hours. joe
rvlover is offline   Reply With Quote
Old 06-23-2006, 07:28 PM   #8
1960 17' Pacer
easton , Maryland
polishing
OK, now that we've ''kicked '' the polishing technique to death, how do we maintain all that mirror finish? I've tryed wax's,both liquid and paste and still have the six month touch ups. Rain drops leave water spots and seems no way to prevent oxidation. Any ideas out there?
peregrine is offline   Reply With Quote
Old 06-23-2006, 07:35 PM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Looks like the 6-month touchups are here to stay. My trailer oxidizes inside my shop, under flourescent lights...sucks.
I am learing that the better the initial finish is, the longer it lasts. I have sections of the same panel that oxidize quicker than others, because they're not quite finished yet.
How do you figure we kicked the polishing technique to death? So far everybody, including myself, has been pretty much doing the same thing with similar tools, no?
Just wondering - no offense intended.
Uwe
Old 06-23-2006, 07:51 PM   #10
1960 17' Pacer
easton , Maryland
polishing
N o offence taken, just my fustration in trying to keep a shiny trailer shiny. Wish there was a answer other than some kind of a clear coat application.
Old 06-23-2006, 08:04 PM   #11
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I've had good luck with Rollites sealer - it goes on with a damp cloth and you wipe off - goes on/off real quick.
Course storing inside does help as does living a dry climate.
Perhaps a little I should mention a little Airstream polish history - way way back Wally suggested kerosene to wipe off the trailer with (I think that generation used kerosene for everything) then Met-All then in 1998 Airmark showed up - lots of folks were using the polish that they sell, then Rollite became the popular polish - seems everybody was using it (we didn't even know about cylos yet - just fancy dewalts) - then there was a rally that the Nuvite folks showed up at and Nuvite became the popular polish - Course there has been acid washes, southern shine and others along the way. I'm sure something else will come along some day...... I think we are all from Missouri (the show me state) when it comes to polishing - and when someone comes up with a dazzeling trailer as the Mannings did, thats when we sit up and listen.
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 06-23-2006, 08:27 PM   #12
lewster's Avatar
Naples, FL , Hood River, OR
I've stayed clear of this topic for many reasons, but I feel that it's time to make a 'contribution'. Folks can use what they like and I don't care of even one person does as I do, if it works for me in the time frame I have alloted to the job, then it is a good product!
I've been polishing metals for 30+ years as a custom goldsmith. Even aluminum! I have products that I use on a regular basis but I have never tried them on a large flat aluminum panel, though I used them on a regular basis on the Alcoa polished wheels of my former MoHo. I recently took a piece of aluminum bar stock that was just siting in my shop and took the initial dull surface down with tripoli, then did a final gloss with green rouge. The section of the bar that was polished has a mirror shine, with most of the scratches and surface imperfections gone. If I wanted a true perfect surface, I would have prepped it with ascending grades of emery and then polished it.
My rear bumper was delivered to me with severe swirl marks in it. It looked like it was clearcoated and after a call to Jackson Center, I was told that Airstream does not use clearcote any longer.....WRONG!!! The bumber IS clearcoated!! Once I remove that and polish it as described above, I'll report back on the results.
I'm always open to new products and techniques. In fact I'm surprised that no one has mentioned the manufacturer of the skins themselves....that being ALCOA!!! They make their own polishing products and make one fine sealant product also. It made a big difference on the wheels of my MoHo and I plan to also use it on my newly polished bumper.
Old 06-23-2006, 08:31 PM   #13
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Ken J.
Hey Ken!
I thought it was interesting that the older manuals say to pour kerosene into the waste water traps as part of the winterizing process. It also states not to use anti-freeze. Maybe that was before the RV non toxic anti-freeze came along...
Richard
Old 06-23-2006, 11:10 PM   #14
I disagree-
And I know thats asking for trouble.
I have found 2 ways of achieving a perfect shine, 1 with buffing wheels, 1 with drum polishing- BOTH without Nuvite- although Nuvite can be used- its just too expensive, BOTH without a Cyclo, and BOTH systems in a lot less time than what the "rule makers" of polishing Airstreams have encouraged everyone to follow.
There is a certain amount of brainwashing thats affecting people here- the "we did it this way and it is the only way" doesn't work with me, I have a different way of thinking and its always worked- it did again, but when I suggest it- it gets hammered here and people end up buying products and spending time that I found ridiculous. I'd rather have my trailer with a smooth acid wash finish than to spend that much time and money.
So far the only member with an open mind and on the right path is Uwe. He's to be commended because he is into his polishing job the "right way" and is looking at doing it differently. Other people that have gotten into the "right way" have written that the time is killing them. Does everyone with a trailer see 200 hours as normal? Efficient?
If its the best way- why don't airlines use it? Why don't professional trailer polishers use it? Why does the system of using a tool that was created to assure damage free and faster polishing to a higher level scare everyone?
I can promise anyone who tries this "wrong way" that once they do, the right way is nothing but laughable. The first trailer I did with this system, was an early 50's, and took less than 30 hours- and it was BAD.
I'm curious how many people here have actually been in a polishing shop, worked with rouge, professional equipment, different alloys. If Lewster is a metal smith in the jewelry field, he has a great understanding of the way different metals react. He knows what I'm getting at, and knows rouge.
Maybe you're right- maybe it has been beaten to death. Maybe trailer folks have a mindset that will always have them buying Cyclos, and using Nuvite, and never realize that its taking 200 hours to do a 25 hour job with 10 times the material expense, because it is an inefficient way of achieving a damage free shine.
Someone who owns an Airstream, and a tow vehicle capable of pulling it, is probably of the financial means to afford the better way, and would prefer to spend all those weekends using the Airstream, than getting soaked in black mud. Why would you discourage anyone from learning that???
Look at it like this- when P&S or Airmark, show up to polish your trailer, does a band of guys get out and spend 3 weeks with a bunch of wobbly Cyclos hanging around your trailer? Then I want to know why I would have to? I want to see if I can replicate, with an affordable way, to be able to do as they do. It takes some investigation, some crafty buying and planning, but its surely easier and less expensive when you pay yourself a wage that you would NEVER work for in your job, which is probably not in the hot sun and getting black mud all over you.
People who don't like it, don't have to read it, or see the reaction when someone does it- just skip the thread- you can think to yourself- "oh well, I don't need to look at that thread- thats just those stupid guys trying to save time and money and do it like professionals do...."
Polishing...approx cost? Drew Cleaning, Stripping & Polishing 10 03-31-2014 10:37 PM
Polishing Again davidz71 Cleaning, Stripping & Polishing 16 11-17-2005 05:40 PM
What Type of Polishing Pad to Use? 68 Suburban Cleaning, Stripping & Polishing 0 10-22-2002 02:28 PM
Anyone else polishing? 64GT Cleaning, Stripping & Polishing 24 08-08-2002 09:19 AM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
