Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 02-27-2007, 10:42 AM   #1
1968 26' Overlander
Marshall , North Carolina
Polishing tip found accidentally
Tired or replacing those terry cloth pads so often? I searched and couldn't find it posted before, but I stumbled on this by accident. If you are using terry cloth pads on a random orbital buffer they seem to fill up pretty quickly. To clean them, simply place an old terry cloth towel on a flat surface and run the buffer for a few seconds on this and it cleans it fast! Also it keeps them from wearing through if you happen to use them too long! I normally get a couple hours use out of a pad before changing them and at the end of the day I throw all the pads and the old towel all in the washer and they are ready for next time I am in the mood to attack another section.
Hank A is offline   Reply With Quote
Old 02-27-2007, 02:27 PM   #2
1973 23' Safari
Maryville , Tennessee
Images: 13
Got any pics of your progress?
kneal is offline   Reply With Quote
Old 02-27-2007, 09:33 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
One gentleman I met used a kind of rake on a roller. It was hand held and he would roll it back and forth for a minute or two on the terry with it still on the buffer. No the buffer was not operating. The rake/roller loosened the residue and fluffed the terry up. I asked where one would get this and he wasn't too clear with me. It may have been a tool for another application.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-27-2007, 10:36 PM   #4
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Neil
I got my rake as you have described for cleaning my pads for a birthday present many years ago. It came from Eastwood products and it works really well. I don't think it cost much money.
Barry
safari57 is offline   Reply With Quote
Old 02-27-2007, 11:55 PM   #5
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I use the end of a screwdriver, with the buffer on slow speed. Just make sure you point it the right way, you don't want it to dig in.
Dave
Fyrzowt is offline   Reply With Quote
Old 02-28-2007, 01:26 PM   #6
1968 26' Overlander
The screwdriver works well on the regular buffer, if you don't have one of the rakes. That's what I use on the regular buffer with the wool and cotton wheels.
Will post some pics soon!
Old 03-01-2007, 10:03 AM   #7
1968 26' Overlander
Follow up with pics,
Here's the link.... Sammy Joe likes the bird
Old 03-01-2007, 10:33 AM   #8
Another tip if the surface is corroded like mine was. Instead of buffing your heart out for hours, get some wetsand sandpaper (depends on how bad the corrosion is) and use anywhere from 600 grit to 2400 grit. Remember, the smaller the grit the more likely it is to scratch as well. I could sand a panel in about 15 minutes or less and have it ready to rouge and shine with the buffer. It also takes off the clearcoat if you don't want to strip and do a little more sanding.. It can be done with an air sander if you want (don't try with electric. Water and electricity don't mix too well.) Test a section first and see how you like the process.
Ken
krwrite is offline   Reply With Quote
Airstream Recreation Association 66TradeWind Our Community 6 10-01-2015 12:02 AM
Polishing tips? Rog0525 Cleaning, Stripping & Polishing 10 04-30-2007 08:27 PM
Awning Tip jcanavera 2000 - 2004 Safari 3 08-29-2003 02:48 PM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
1985 310 found off road ViewRVs General Motorhome Topics 1 05-27-2002 12:15 PM
