Old 07-26-2005, 07:36 PM   #1
Charcigar's Avatar
1967 22' Safari
Coquitlam , Beautiful BC
Polishing the Worthington Tanks?
I have ordered 2 x 30lb tanks to replace my silver painted ones.Plan is to polish them up.I have polished my trailer with the Cyclo and Nuvite polishes,so am very familiar with that method.
Just wondering if anyone has any tips or advice for polishing the tanks?Same procedure?Anything different I should know?
Charcigar is offline   Reply With Quote
Old 07-26-2005, 08:07 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I did ours...you will find that the top where all the valves & stuff are will had to be done by hand or with a dremmel. Yuck! The tanks were my job...
Shari
Old 07-26-2005, 08:30 PM   #3
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
You can use the same materials and procedures for polishing your tanks that you would use on your trailer. My experience was that the tanks will arrive out of the box with many gouges and blemishes and you will have to address these before beginning to polish. I used a scotch bright pad on an air die grinder to smooth the major scratches and welds prior to beginning to polish. Then, just proceed as you would normally, with a rotary buffer and nuvite and work your way through the grades of polish and finish up with nuvite S and the cyclo.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
LP Tanks Craig LP Gas, Piping, Tanks & Regulators 6 08-22-2002 08:43 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
