Old 11-07-2012, 06:28 AM   #1
ragin-cajun's Avatar
1961 16' Bambi
Malden , Missouri
Polishing the Bambi
I only get to work on this project on Fridays, so I know it's going to take a while. But after only one day of working on it, I must admit that it's rather addicting!
ID:	172230   Click image for larger version
ragin-cajun is offline   Reply With Quote
Old 11-07-2012, 06:32 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Looking good, when you get thru you can come down and do mine. It needs a little touch up.☺
MICHAEL
Old 11-07-2012, 06:40 AM   #3
1961 16' Bambi
Malden , Missouri
LOL I'll keep that in mind!
Old 11-07-2012, 08:21 AM   #4
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
It took us a day (8 hours) a foot.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 11-07-2012, 08:26 AM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
Wow, done in 16 hours for both feet! Just kidding... nice work.
Old 11-09-2012, 06:39 PM   #6
1961 16' Bambi
Malden , Missouri
Okay. Still working on the front end-cap and making great progress on the upper half. I'm using Nu-Vite F7, but it's not cutting through the little peck marks on the lower area (see pic). Do i need a coarser compound or just more elbow-grease? Also, that scratch mark feels more like paint--any ideas for removing?
Thanks in advance for the input!
Old 11-09-2012, 07:52 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I have a Bambi II that I've done a little polishing on. It is BADLY oxidized everywhere. I have used this method with pretty good results, although it's very time consuming:
1. Right angle air drill with very fine grey scotchbrite pad
2. Black bar with wheel
3. Wet sand with 600,800,1000 (by hand)
4. Compound with F9, F7, C,
5. Cyclo with S
Now, maybe yours isn't as badly corroded as mine, so you can skip steps 1 & 2 & 3 and try F9 first. If that doesn't do the trick, move backwards on the list until you find that it's working for you. Just be glad it isn't a 31 footer!
Here's mine through step 3 and compounded with F9--I haven't finished yet--I just wanted to see how it would look:
Name:	a bit of polish finished 2 oct 25, 2012.jpg
Name:	a bit of polishing finished october 25, 2012.jpg
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-09-2012, 08:05 PM   #8
1961 16' Bambi
Malden , Missouri
Beckybillrae
Thanks for sharing! Pics looking good.
Old 11-10-2012, 03:27 PM   #9
1961 16' Bambi
Malden , Missouri
Made some progress today with my helper! (She had rivet duty.)
Old 11-10-2012, 08:52 PM   #10
1964 17' Bambi II
Laramie , Wyoming
Images: 11
We used the green bar from Caswell and a 10' wheel on the tough areas.
Antique Pedaler
Old 11-18-2012, 01:15 PM   #11
1961 16' Bambi
Malden , Missouri
I'm now 19 hours into the polishing! I'm waiting on my Nuvite F9 so I can get the imperfections out of the front bottom panel and polishing wheels so I can get into the tighter spots.
ID:	172915   Click image for larger version
Old 11-18-2012, 01:44 PM   #12
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Looking absolutely great!
Antique Pedaler
Old 11-24-2012, 03:49 PM   #13
1961 16' Bambi
Malden , Missouri
Question: how do you get the water stains off!? I've used F9 F7 and C but they still show! Am I missing something or just not taking enough time on it?
Old 11-24-2012, 04:07 PM   #14
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
compounding with C then Cyclo C then Cyclo S. I fight this problem all the time.
