Old 08-29-2011, 03:37 PM   #15
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by Darkspeed View Post
No problem. Don't forget to order a wheel rake. I just got the one that screws to a table.
Thanks for the reminder just added it to the order.
Mike
desertair27 is offline   Reply With Quote
Old 11-02-2011, 05:14 AM   #16
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
Did the Jasco remove the club number decals?
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
Old 11-02-2011, 06:59 AM   #17
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
The stripper removed most of them except for a ghost image.
The polishing removed any trace of them.
Darkspeed is offline   Reply With Quote
Old 11-06-2011, 06:17 PM   #18
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Images: 8
Oh, good. I am looking forward to removing those red numbers.
Anne
Indianapolis, IN
TAC IN-7
Old 11-09-2011, 10:19 PM   #19
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
If I polish Old Gertrude it's by some one "NOT ME" All your photos look great!!!
alfalsetto is offline   Reply With Quote
Old 11-10-2011, 06:21 AM   #20
Darkspeed's Avatar
1972 31' Sovereign
Thanks!
Old 11-10-2011, 06:22 AM   #21
Darkspeed's Avatar
1972 31' Sovereign
Wanted to add this detail about the adapter...
The adapter is from a 5/8" 11tpi female to a 1/2" male- assuming you ordered discs with a 1/2" hole..
http://www.caswellplating.com/buffs/grinderadapter.html
Old 11-10-2011, 06:40 AM   #22
Darkspeed's Avatar
1972 31' Sovereign
Remember to run the new disk on the rake for a moment to fray the outside edge before adding compound from the black bar. The first time you polish with a new disk they won't do much for the first few min. They need to break in to accept compound.
Old 11-11-2011, 09:38 AM   #23
I agree with that statement!
Darkspeed, do you use a different pad for the white bar?
The vented ones are quite stiff, and I wondered if using a softer pad would help...
Old 11-11-2011, 12:33 PM   #24
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
That looks great, I have been struggling with getting off the corrosion and small scratches. Got some off with Nuvite, but not enough. I will give the lack bars a shot though. Great tip.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-11-2011, 03:14 PM   #25
Darkspeed's Avatar
1972 31' Sovereign
I did use a fresh vented disc with the white bar.
The cotton discs I have did not seem to work as well as the vented.
I may try some nuvite s with a random to finish it off once i stop working on the outside.
I have repolish with white from all the cords,sanding dust, tree sap, degreaser,etc... that i have managed to get on her while working.
Old 11-11-2011, 04:03 PM   #26
Darkspeed's Avatar
1972 31' Sovereign
Another thing that may help when polishing out scratches is to know what part of the wheel is doing the most cutting... Its the first 3/4" where the wheel meets the aluminum..
Old 11-12-2011, 07:34 AM   #27
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
You said you bought
3 3lb black Emory bars
2 3lb white fine bars
Did you use all of that?
You didn't use any brown?
Also for a final pass with the white was the buffing wheel leaving any scratches, the reason I ask is the cotton is recommended by some.
'77 Sovereign Intl 31' CB
Old 11-12-2011, 11:29 AM   #28
Darkspeed's Avatar
1972 31' Sovereign
Originally Posted by LI Pets View Post
You said you bought
Yes used it all..
After the white you could not see any scratches dead on, but if you looked at an angle in the sun you could see a faint pattern. From there you would need a random orbital to get rid of it.
My Anodized aluminum Silver Streak polishing project Hueytownalss Cleaning, Stripping & Polishing 44 04-15-2017 08:53 AM
The Aluminum Falcon Darkspeed 1970 - 1973 Sovereign 276 07-15-2016 01:38 PM
Aluminum Falcon :: 1967 Airstream Safari Chadius Airstream Registry Discussions 3 04-03-2012 10:59 PM
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 05:47 AM
