Old 03-09-2010, 06:16 PM   #1
1968 24' Tradewind
Lowesville , Virginia
Polishing questions
Working on our 68 Tradewind....trying to polish the spots where trim and all can go back on and have run into some challenges. On the upper sections (close up picture) it works as folks describe pretty much.....buffer creates the black residue and then produces a nice shine...using Nuvite #7 presently.
BUT on the sides, there appears to be a coating that I have to literally grind through with the compound...lots of compound, lots of pressure.....an hour will get about 6 to 8 sq. inches done! Note in the picture of the rear section the difference between the shined area and that next to it. I have used strippers of all kinds, lacquer thinner, mineral spirits.....all to no avail. Any thoughts would really be appreciated.
Interior is going back together by the way....after a long 2 month winter hibernation period.
Name:	polishing question 1.jpg
ID:	97804   Click image for larger version
Name:	polishing question 2.jpg
shimps is offline   Reply With Quote
Old 03-09-2010, 06:34 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Looks like you have not removed the clear coat yet. Have you?
This section might help you. Cleaning, Stripping & Polishing - Airstream Forums
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-09-2010, 07:18 PM   #3
1968 24' Tradewind
that's what I am thinking.....but I did all the stripping steps that I could find, using every manner of solvent....or so I thought.....is there a sure fire way to strip this off?
Old 03-09-2010, 07:22 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Have you tried aircraft stripper? It comes in a spray can & can be found at Auto Zone or Advanced Auto.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-09-2010, 08:23 PM   #5
Airdog's Avatar
1972 31' Sovereign
Pittsford , Michigan
The Plastic-Coat was thick on the sides of the trailer. Very thine to none at all on the roof and curves of most of the roof. The plastic-coat came off like blistered skin off the sides. It was necessary to apply the remover several times to get it all off. I had the best results when I left it on for a while. I would apply it to the whole side, go back to where I started and then scrub it with a truck wash brush, reapplying as necessary. Don't be in a big hurry to wash the stripper off. It will continue to work with the
chucks of plastic-coat in it. Hang in there, it's worth the effort!
----Bill & Elaine----
TAC # MI-4
Pittsford, Michigan
"part of the "Forbidden Wheels Clubhouse Recon Team"
"Toast is a tool. It ain't Breakfast!"
Airdog is offline   Reply With Quote
Old 03-11-2010, 05:15 AM   #6
1968 24' Tradewind
stripping questions
Thanks all....I am encouraged....again....and will try some of the aircraft stripper you all recommend. Thank you so much for taking the time to help on the forum!
Supposed to rain for a few days, so time to check those last pesky leaks and then actually start on inside bathroom and plumbing and all....it will be nice to have space in my shop again without working around piles of AS parts!
Old 03-11-2010, 07:01 AM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
It also comes in a gallon can that you brush on. Having used both, I find that to be more economical and easier to use because you can put it on thicker and it works better. Not to mention there isn't overspray...and all those little cans.
Shari
Old 03-11-2010, 08:24 AM   #8
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Aircraft stripper
Shimps,Try to find the Kleen Strip Aircraft Stripper in the blue can with the airplane on front.The main ingredient is ammonia.The one that is not marked"low odor" is the one to use.I used both and it works better.(the formula is different) Got mine at a body shop -paint supply.Removall220(available at VTS now is also good though I have not used)
I put on starting at the bottom.I let sit for about 10 min. or so then used a small nylon brush to make swirls .When I finished I let sit another 5 then power hosed off.
I did have to go back and do tough spots (and you will see what you missed.
CAUTION!!! This is tough stuff so use rubber gloves,a really good two side mask,and eye protection.
On a 28 ft. it took me about 3 days to get it all.
ID:	97915   Click image for larger version
bwaysteve is offline   Reply With Quote
Old 03-20-2010, 12:13 PM   #9
Archersfin's Avatar
1986 34' Excella
Conroe , Texas
I don't know what the outside temp was when you tried to strip the last time, but be sure it is above 55 deg or the stripper will not work as well if at all. I'm giving you this from experience.
Archersfin is offline   Reply With Quote
Old 03-21-2010, 04:05 PM   #10
1968 24' Tradewind
Stripping the Tradewind
Thanks again all.....picked a few warm days and it was amazing....all done now and doing a bit of polishing when I get tired of fitting drain lines and all.....took some god pictures that I plan to include in my "saga" one day....
Old 03-21-2010, 04:56 PM   #11
DD.KARAOKE's Avatar
1976 Argosy 20
Peralta , New Mexico
Images: 12
Does this stuff work to take off the argosy paint?
I have a 76 Argosy 20 TT and the ends look like this.
Name:	ARGOSY 20 FRONT.jpg
Name:	ARGOSY 20 REAR.jpg
so you can see why I want to strip it.
Also I was wondering if anyone else has a "SHINY" Argosy?
Dorian
AIRFORUMS # 44025
TAC # NM-2
TAC - We are dead-serious about having fun!
TAC's unofficial KARAOKE Provider
DD.KARAOKE is offline   Reply With Quote
Old 03-21-2010, 05:49 PM   #12
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Dorian
I would consider preping it and repaint it. You can paint it aluminum, which would have a comparable finish to an Airstream with clear coat but last several times longer.
I assume you know Argosy endcaps are galvanized..
Old 03-21-2010, 10:38 PM   #13
DD.KARAOKE's Avatar
1976 Argosy 20
Images: 12
no I did not, thanks now I have to buy paint
AIRFORUMS # 44025
TAC # NM-2
Old 03-21-2010, 11:16 PM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Dorian
Aircraft Stripper will remove the paint, but you will have to repaint when you're done.
Polishing questions peejicky Cleaning, Stripping & Polishing 42 05-10-2008 06:26 PM
Questions about polishing an aluminum trailer? 72Blazerod Cleaning, Stripping & Polishing 7 08-09-2005 08:17 PM
Polishing Questions for the Gurus'. surf'n safari Cleaning, Stripping & Polishing 2 02-19-2005 05:14 PM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
