Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 05-02-2008, 07:14 PM
peejicky
Profile:  1971 31' Sovereign
Savannah, Tennessee
Polishing questions
I've started polishing my trailer using Nuvite products, compounding, and cycloing. I'm getting a good shine but there is almost a grain to the aluminum that can be seen when looking into the reflection. I've used three passes with G6 (compounding), two with C (compounding), and one pass with the cyclo and S. There is no serious corrosion on the aluminum. The side you see polished had very little clearcoat (it was stripped) and the aluminum was oxidized. This was removed easily by the G6. The other side however had full clearcoat and no oxidation. After stripping the clearcoat there is a film(?) on the surface that stripper will not remove. I have provided closups and hope they show what I'm talking about. It has spots that look like popped bubbles and a few places look like brush strokes. No stripper I've tried will remove it so It appears to be part of the aluminum. I've tried the G6 and this film is VERY hard to remove. Here are my questions:
1) Are most of you compounding the grain out of the aluminum or do you leave it?
2) Is the film I'm speaking of on the streetside part of the aluminum surface?
3) How many passes with each grade (applying polish and compounding it) are you guys/gals using?
4) Does anybody have a window to sell? I'm missing the 30 X 22 over the sleeping area?
5) I have two panels to replace on the front of the trailer which appeared to be from jack knifing. What type of aluminum should I use? I plan to purchase it from Airparts Inc.
Thanks in advance for your help. I'm a daily reader of the forums. It's an addiction I think.
P.S. I know I need new axles (LOL)
Name:	chattanooga 169smaller.jpg
ID:	59678  Click image for larger version
Name:	chattanooga 172smaller.jpg
Name:	chattanooga 173smaller.jpg
Get rid of these ads... register today, it's FREE
Old 05-02-2008, 08:24 PM
62overlander
not the shiniest rivet
62overlander's Avatar
Profile:  1962 26' Overlander
Catonsville, Maryland
Try this stuff sold at Lowes first, then go to Nuvite if you feel it is necessary.
Diamond Brite has made the job 150% faster. Are you sure the clear coat is off? Does black appear instantly after you apply that Nuvite?
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
Old 05-02-2008, 08:29 PM
62overlander
you want 2024 T3 .32 thickness. Tell Diana Frank said hello, Those folks are so excellent to deal with. Just to piss on your campfire a little: to do it right, you need to remove the inner skins and buck those rivets. Olympics are not acceptable in structural repairs, you will need to buck them. Have no fear, it is fun and easy, way cool too... jump in have no fear.
Old 05-02-2008, 10:11 PM
Jim Foster
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
Walnut Grove, California
Between compounding with "C" and cycloing with "S", I cyclo with F7. Cycloing with "S" will not remove the swirls left by the coumpounding.
The compounding should make the surface very smooth. Be careful that you are not using too much polish. "Rake" your compounding pad from time to time to keep down the build-up of polish and aluminum material.
Old 05-02-2008, 11:21 PM
Not Done
Profile:  1973 31' Excella 500
Marysville, Washington
Try a peice of plexiglass to replace the glass in that window. Worked for me. the corners were a bit tricky since you cut in straight lines. Three straight cuts provided enough radius to pass as a corner. Sounded hokey then I saw that others had done this before me so I felt justified. If nothing else you can use the plexiglass untill you find real glass.
Old 05-03-2008, 12:30 AM
goransons
goransons's Avatar
Profile:  1969 25' Tradewind
Yakima, Washington
I polished most of the graining out, but since we're storing it outside I didn't go to overboard. I did work really hard to get rid of the pitting, but yes, lines that look almost like roller marks were reduced, but totally removed. I found C did a good job of those lines btw.
Old 05-03-2008, 01:21 PM
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:
Maybe your AS was re-clearcoated, and etched first. That "film' does look like brushmarks. Again, are you sure the clear coat is off that "film" area, does it turn black when you compound it?
Those bubbles look like filform... which is caused by oxidation under the clearcoat. Nasty stuff. Try F7 or harsher to cut through it, then G6.
Your curbside looks great, btw!
Keep at it!
Marc
Old 05-07-2008, 02:51 PM
themunks
Profile:  yuma, Arizona
We just about finished up our polish job. Everytime the guy would finish, we would find something or want it brighter. We have a 84 soveriegn and it has been polished twice now. Maybe have to go for 3.
This pic is when the new wheels were put on, getting close.Click image for larger version
Old 05-07-2008, 05:05 PM
vhord
vhord's Avatar
Profile:  1970 27' Overlander
Crosby, Texas
Rivet selection
I too have two forward corner panels to replace. I thought I had read that Olympic rivets were acceptable on exterior wall sheets. I can't find it now but I think it was Andy at Inland that said it. I have my inner skins removed but do not have the tools or experience to buck rivet them.
Any advice will be appreciated.
Vernon
Crosby, TX
1970 27' Overlander Restoration
Photo gallery
Old 05-07-2008, 05:34 PM
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange, California
vhord,
Bucking rivets is not complicated, but a lesson would be a good idea. The equipment is a air chisel, available at Harbor Freight for about $10, a bucking bar, available at Aircraft Spruce for about $10 and up, I bought this one :P/N 12-01298, rivet sets, available at Aircraft Spruce for less than $10, rivets, correct drill bit, available from Inland for about $10 or so and an air compressor.
Since you have the inside skins out, buck rivets would be better than olympic rivets.
I would be glad to show you but you are a little far away.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 05-07-2008, 05:48 PM
n2batr
Profile:  1958 26' Overlander
Lander, Wyoming
side window
I may have your window. Do you need the riveted frame and window or just the window glass and inner frame? The measurements I have on this one are 22x30.5 glass plus inner frame. Let me know. Ed
Old 05-08-2008, 04:30 AM
62overlander
You have to buck them.... olympics will not hold up to the stress. One or two to replace a rivet that has lost it's grip is okay. Or mounting an object, but not a skin. I am very surprised to hear someone say that it was an exceptable practice to use olympics for structural repairs. It is actually much easier than you think. Just remove the interior furniture and skins. You will have complete access to the backside of the exterior skin. Aerowood has excellent pictures of how he did it. He did go the extra mile and is treating it like a plane being built for the defense industry, but he shows exactly what needs to be done. You will need a bunch of clecos too.
Ed, Are you offering more hard to find parts? Ed was the kind person that supplied my with my missing drip cap. I installed it a few weeks ago and am now polishing in that area. Thanks again Ed.
Old 05-08-2008, 07:09 AM
vhord
vhord's Avatar
Crosby, Texas
Sorry, I really don't want to beat a dead horse but I had to look back in the forum to make sure that I had not dreamed something. One of the threads that I was referring to is this one.
Also, if buck rivets are a must I may have a problem with a large sheet that was apparently replaced on the street side by the PO or dealer.
The picture is of a horizonal rib but the vertical ribs are also attached with olympics. I want to do this right the first time but also I do not want to do any unnecessary work. Believe me I have plenty of other work to do.
Thanks everyone for their input.
Vernon
Crosby, TX
Photo gallery
Old 05-08-2008, 10:23 AM
Inland RV Center, In
Commercial Vendor
Profile:  Corona, California
You have to buck them.... olympics will not hold up to the stress. One or two to replace a rivet that has lost it's grip is okay. Or mounting an object, but not a skin. I am very surprised to hear someone say that it was an exceptable practice to use olympics for structural repairs. Ed.
Olympics are a fastener. Any fastener can cause a problem if not properly used.
I helped getting the present style Olympic rivet to the market place about 37 years ago, when I was with the Insurance division of Airstream, called Caravanner Insurance Company.
The Airstream factory uses them to replace complete sheets, as well as the dealers that do that kind of work, including ourselves.
Olympics are very acceptable to repair any part of the shell, when used properly.
If not used properly, then 1000's and 1000's of sheetmetal repairs jobs would be falling apart all over the world, which they are not.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
vB code is On
Pingbacks are On
Polishing a 94 Craftsman Cleaning, Stripping & Polishing 4 08-18-2005 12:58 AM
Questions about polishing an aluminum trailer? 72Blazerod Cleaning, Stripping & Polishing 7 08-09-2005 08:17 PM
Polishing Questions for the Gurus'. surf'n safari Cleaning, Stripping & Polishing 2 02-19-2005 05:14 PM
polishing jimmy Cleaning, Stripping & Polishing 0 07-20-2003 12:22 PM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
