Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 05-08-2008, 01:02 PM
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Edgewater, Colorado
Andy, please define "when used properly".
We are embarking on major panel replacement projects on both of our trailers this weekend. One ('56) bucked and one ('64) w/Olympics...I would sure like to know how to use Olympics "properly" prior to starting to keep from having to do this twice.
Also, how would one use Olympics improperly...doesn't seem like there are too many options on how to use them, they're actually pretty simple technology ~ put it in the hole (w/Vulkem), pull it, shave it.
Shari
Vintage Airstream Club - 2007/2008 President
RMVAC | WBCCI DenCO Unit | My Trailer "Maxwell" | My Trailer "Birdie"
Get rid of these ads... register today, it's FREE
Old 05-08-2008, 02:18 PM
62overlander
not the shiniest rivet
62overlander's Avatar
Profile:  1962 26' Overlander
Catonsville, Maryland
There are many ways to skin a trailer. There are many different opinion as to the right way. You choose for yourself. I know that I, Me, Myself will not be doing any kind of structural repairs with olympics. I will be using solid rivets. I think solid is the right way to go. I do not have 37 years of experience, but I do have my opinion. Ironically, my opinion is shares by many other, some are actually called professionals. Putting on a patch, a 46" drip cap, a belt line, well, I say perfect fit. Replacing a panel, not the right fit.
You decide for yourself....
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
Old 05-08-2008, 08:10 PM
Inland RV Center, In
Commercial Vendor
Profile:  Corona, California
Status: Online
Olympic rivets
Shari
Buck riveting permits sloppy workmanship. The holes thru the metal don't have to be straight, the holes can be the wrong size, the rivet gun can be held at an angle, and all is forgiven, because the rivet swells.
Using Olympic rivets takes a little more care and technique.
The drilled holes must be reasonably straight, and the rivet gun must be held at 90 degrees from the metal.
Olympic rivets do not swell like buck rivets.
Olympic rivets should also have a small bead of Vulkem placed around the shank of the rivet, before it's inserted into the hole. When that is properly done, the Olympic rivet is sealed behind the head and around the shank, once the pin is pulled.
Buck riveting work must be sealed from the backside, therefore no sealer is under the rivet head or around it's shank.
Buck rivets are much cheaper than Olympic rivets.
Using a #21 drill bit for Olympic rivets is correct, not #20 as some choose to do. A #20 allows way too much slop for the rivet shank.
OLYMPICS WITH WASHERS IS AN ABSOLUTE NO NO.
Why???
The rubber washer deteriorates in time, and when it does, every rivet that used the washer, will leak. Who ever came up with the idea of using rubber washers with Olympic rivets, on an Airstream, did not think very far into the future. It at best, is a very poor way to do proper metal replacement.
Sloppy workmanship, is never an acceptable excuse when working on sheet metal replacement.
Segment replacements should have a bead of vulkem injected between the seams, then riveted. Same way with the lower and window sheets.
The roof sheet is handled differently. After all the rivets holes are drill in the roof sheet, the sheet is set aside so that all the metal shavings can be removed. Then, a good bead of Vulkem sealer is placed on every main bow and horizontal stringer, and on the adjoining metal. The roof sheet is then placed back into position and riveted with Olympics.
Using that procedure will insure a roof replacement, with NO leaks.
There is a specific technique that must be used, regardless of the type fastener, nails, screws, rivets and the like.
If not done properly, most any fastener system used, will become inadequate in short order.
Using Olympic rivets is a piece of cake, BUT, using the proper technique, is a must, since they are not as forgiving as a buck rivets, but they certainly have more than held up to the task.
Using Olympic rivets will hold an Airstream together just as well as buck rivets, any day.
35 plus years of use, more than demonstrates that fact.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 05-08-2008, 08:26 PM
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock, North Carolina
Well written and well said Andy.
Keep the shiny side up.
WBCCI # 3485
Region 3 2nd VP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Old 05-08-2008, 08:38 PM
62overlander
Why???
And that is why an airstream is constructed of what kind of rivets? SOLID RIVETS......
Old 05-08-2008, 08:39 PM
62overlander
More than 75 years has demonstrated that.
Old 05-08-2008, 09:25 PM
  #21
Commercial Vendor
Status: Online
One Olympic rivet equals about 100 buck rivets, in cost.
One bolt and nut equals about 100 nails, in cost.
The labor per installed buck rivet, is much less than an Olympic rivet.
Inlandrv.com
Old 05-08-2008, 09:31 PM
  #22
n2batr
Profile:  1958 26' Overlander
Lander, Wyoming
Yes Frank, I think I have the window he needs. The measurements are right. Whenever I see someone post a part need on the forum and I have it I'll try to get it to them. I'm sure I'll be in need of many parts as my restoration continues and hopefully someone here will have them. Hopefully I'll get it for him in a week or so after I return from vacation. Glad to here the drip cap worked for Anna. She looks sweet. Ed
Old 05-08-2008, 09:58 PM
  #23
robandzoe
robandzoe's Avatar
Profile:  1958 30' Sovereign of the Road
1965 17' Caravel
Plymouth, New York
Buck Rivets
Bucking is the way to go! If you want it to last... buck em. If you want it to be structural - buck em! If you want to save $$$ and cut corners, Olympic them!
Rob, Zoe', Stanton, Bryce and Braedon Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Courtesy parking: Central New York, W/E-30 A/WIFI
(607) 334 4960
58 30' Sovereign of the Road:
http://sweetsovereign.blogspot.com
65 17' Caravel
54 22' Safari
1959 Buick Electra
Old 05-08-2008, 10:01 PM
  #24
62overlander
If the olympics were structural, they would be FAA approved.
Old 05-08-2008, 10:31 PM
  #25
goransons
goransons's Avatar
Profile:  1969 25' Tradewind
Yakima, Washington
Status: Online
So I probably should just keep my mouth shut, but why do some posts on here go the direction of if you don't agree, say something that could be taken as rude or objectionable (maybe I'm just too tired and am reading into them wrong?!?)? I mean we all have our opinions and our experiences but sometimes I hate reading threads when everyone sharing their advise turns into cutting down anyone that doesn't agree.
Certainly there are people that have the time, money and facilities to pull interior panels, but not all of us. I'm 100% about doing the job right the first time, but our AS has 4 panels that were replaced by the original owner 20 years ago, all done with Olympics and all don't leak, and there are no structural problems. While I respect that a Buck Rivet might be stronger than an olympic rivet, I too know from growing up in a Boeing Family that the stress load on panels on an airplane are much higher than any Airstream will ever see.
Sorry, I'll put my soapbox away.
Old 05-09-2008, 04:08 AM
  #26
62overlander
You are very right... sorry. Do it however. There are many ways to skin a trailer... I will say no more on this ever.
Old 05-09-2008, 07:32 AM
  #27
jkcru
jkcru's Avatar
Profile:  1976 23' Safari
Escondido, California
Is that a promise?
Old 05-09-2008, 08:23 AM
  #28
62overlander
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jhenry
vB code is On
Pingbacks are On
Polishing a 94 Craftsman Cleaning, Stripping & Polishing 4 08-18-2005 12:58 AM
Questions about polishing an aluminum trailer? 72Blazerod Cleaning, Stripping & Polishing 7 08-09-2005 08:17 PM
Polishing Questions for the Gurus'. surf'n safari Cleaning, Stripping & Polishing 2 02-19-2005 05:14 PM
polishing jimmy Cleaning, Stripping & Polishing 0 07-20-2003 12:22 PM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
