Old 03-20-2006, 10:47 PM   #1
1966 22' Safari
san diego , California
Polishing Question - sooo much black
I'm in the process of polishing my trailer. These are the steps I'm taking:
On the real pitted areas (mainly roof):
1) I'm wet sanding w/ a 150 grit (yes, 150, it seems to be the finest grit that works - very deep pits & they're still visible but don't want to go coarser)
2) Then I use a 220 grit
3) Then a 500 grit
4) Then an 800 grit
5) Then I'm applying a 3M rubbing compound with a compounding bonnet and polishing tool. The compound that says it will remove scratches from a 1000 grit sanding
6) Then I'm polishing with Mothers (tried Walberneze, doesn't work)
All of this took 2 hours for a 2x2 area.
PROBLEM I'M HAVING: There is sooo much black coming off with the compound, and caking up on the surface and pad, that even after applying the polish the area looks spotty and uneven. Some spots are shinier than others and there's something looking like stains in areas where the black seems to not want to disappear no matter how much I buff it. When I buff by hand, however I gey a better result.
Overall, its shiny, but uneven and not mirror - it seems to be LOADS of work.
QUESTIONS:
1) Should I use yet a finer grit sand paper before compounding?
2) Should I compound it twice?
3) Will mineral spirits remove the staining?
jlandau is offline   Reply With Quote
Old 03-20-2006, 11:42 PM   #2
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Is the staining the black oxidation that you cannot remove, if so take some flour for bakeing rub that over the black that you cannot remove it's fine enough to get into the pores and will not scratch the surface. use to use that all the time on truck wheels after applying mothers.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 03-20-2006, 11:51 PM   #3
1966 22' Safari
Thanks - I'll try that. Do you think it will even out the appearance of the polished areas?
Old 03-20-2006, 11:56 PM   #4
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Not sure about that,, you might half to do some spot touch up. the flour works really well though to remove that black slime, hope it all works out for you..
Old 03-21-2006, 03:48 AM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up You gotta
jlandau,
You realize that working on the roof is quite simply the worst area for oxidation.? It's here that you're gonna have your slowest time, the darkest mess, etc. Just take your time and, stay focus. Worry abt the eveniness of the shine afterwards..It's just gonna take an unbelieveable amount of time and effort the first time around because you have years....years worth of oxidation to remove.
Keep up the good work, I'll stop by from time to time to check on your progress..
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 03-21-2006, 05:23 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Also, when you get done polishing a spot, wet a shop towel with mineral spirits and use it to wipe off the black gunk that is left on the skin. Youwould be suprised how much better it looks. I spent hours trying to polish a single panel, all I was doing was moving the gunk around. It started going a lot faster when I wiped it down with the mineral spirits.
Old 03-21-2006, 07:01 AM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I have experienced the same issue above the window line on my 1963 Overlander. It seems that a courser polish cuts the oxidation much faster, and a consistant buffer speed makes this a little bit easier. But it is a bear nonetheless.
On my trailer, the Heavy Metal polish worked best for problem areas. Not that I am even close to being done....
Uwe
www.area63productions.com
Old 03-21-2006, 07:14 AM   #8
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Sandpaper--Ouch That hurts. There are so many good threads here on polishing and many debates on the use of sandpaper. I use it for my woodworking, on Chummy the swirls would never come out! Stop what you are doing, please. Steve at Vintage Trailer Supply, an advertiser here on the forums, an AS owner and a good guy puts out a really nice sheet on how to polish. Give him a call and get a copy. If you are so inclined he also has the right stuff to do the job.
http://www.vintagetrailersupply.com/
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 03-21-2006, 07:45 AM   #9
Elgin , Texas
Images: 164
jlandau,
How about posting a pic so we can see what you're up against?
bake315 is offline   Reply With Quote
Old 03-21-2006, 09:18 AM   #10
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I've tried this and didn't get great results. Is there some technique for applying the flower, eg, do you buff it on, like polish, or rub it on with a dry rag, maybe a damp rag?
Old 03-21-2006, 09:54 AM   #11
Elgin , Texas
Images: 164
Pretty sure the rag and flour has to be dry, otherwise it's just one more thing to have to wipe off.
For the stage you're at, jlandau, I'd say get some odorless mineral spirits, throwaway cloth rags and nitrile gloves, and wipe away the gunk after each pass. Until the surface becomes a little more uniform, you're going to have some splotchiness, especially on the roof. It'll come around for you eventually.
Old 03-21-2006, 10:28 AM   #12
Fullerton , California
Does jlandau's AS have a clear coat? I know they started that sometime in the 60's but how about 66? If that isn't removed first it could account for the spotting. The reason I ask is we are having a lot of the same issues with the "black stuff" in the pitted and scratched areas on our 55 but not the spotting that jlandau described.
This is a lot of work! The more you buff the more buffed you will be!
Lynn
cloud55 is offline   Reply With Quote
Old 03-21-2006, 12:20 PM   #13
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
"Led", I would just slap the flour on after i was done polishing with Mothers, and would rub it around with my hand were I had just pollished to remove the black oxidation then would pollish by hand with cheese cloth always turned out great. Would always do this with truck rims, air & fuel tanks and if there was a pit in the surface would use flour and a toothbrush to remove black oxidation form pit.
Old 03-21-2006, 05:02 PM   #14
Over59's Avatar
Putnam , Connecticut
Images: 37
Could you have overheated the surface with your polisher and caused a tinting on the metal. It's my understanding that this will not change back once it occurs.
Over59 is offline   Reply With Quote
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
