Old 04-17-2010, 02:41 PM   #1
tdoescher's Avatar
1969 31' Sovereign
Madison , Wisconsin
Polishing Question - Hard to Reach
I am going to start my summer project and Polish my 1969 Airstream Soveriegn.
Here is my question how do I polish around all those little areas for example the front top where it has the Airstream metal letters.
How do you buff in those tight areas and in the nick and crany areas?
Any methods or special tools you have used that I should get or do???
Was going to order the Dewalt 7 inch polisher and polishing kit from
Vintage Trailers
Thanks Todd
tdoescher is offline   Reply With Quote
Old 04-17-2010, 02:53 PM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I have used my little finger and wooden Q-tips....Hot dog sticks with t;shirt wrapped around. I also use a drimel that has some fittings that get in there. I did use a drimmel polishing wheel to do the window frames and that came out very nice. I also use 3M gravel in a bottle to begin each detail session. Good luck!
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 04-17-2010, 05:49 PM   #3
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Polishing Tools
Drimmel polishing wheel for windows. Great idea! I have just finished compounding our 65 22' Safari and am getting ready to buff with the Cyclo and Nuvite S. I have struggled with the window frames and the Dewalt grinder. Every few minutes it takes me for a ride when it flies off the frame. We purchased our polishing kit from Vintage Trailer Supply. We are on our 3rd jar of Nuvite 7 due to much corrosion. Best of luck......Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 04-19-2010, 09:13 AM   #4
1970 27' Overlander
The cotton fittings for those drimmels last a little while, so I am prepared to remedy that with some sort of longer lasting replacement. But I will take the 3M 'gravel in a bottle rubbing compound on my finger and rub back and forth at first on those window frames. Then hop to it with the drimmel wheel (careful not to burn up the machine) and moving with the grain I get a great finish. If you would do the 3M Rubbing Super duty rubbing compound, you would be knocking through all that built up 'crud' and can cut to the chase with the nuvite.
Old 04-19-2010, 04:09 PM   #5
1986 32' Excella
vledder , drenthe
Images: 8
Just drill out the few rivets that holds the emblem.
drilling out a few rivets and reinstall only takes a few minutes.
polish around the emblems takes a few hours.
remcolent is offline   Reply With Quote
polishing question jeffinwnc Cleaning, Stripping & Polishing 10 12-07-2009 11:38 AM
question about polishing... katzklaw Cleaning, Stripping & Polishing 39 03-25-2007 02:56 PM
OK all you polishing folks, don't laugh too hard bake315 Cleaning, Stripping & Polishing 12 03-17-2006 05:42 PM
Plumbing hard to reach DaveJ General Motorhome Topics 7 04-15-2004 08:40 PM
