Old 01-31-2011, 01:19 PM   #43
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Oh I forgot the best part it has now stopped raining and we are going to work on polishing some more this afternoon.
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 01-31-2011, 05:42 PM   #44
vintage travelers
scorpiontimo's Avatar
1972 31' Sovereign
Johnson City , on the road
Images: 20
Now you got it nothing like a fresh polish on a Airstream to make the day. When we did ours we tryed different tec's now we only use Jesco bars to compound than finish with S grade and a Porter orbit, our 31et took 120hrs plus, now we are using s grade this week to get the 6,500 miles of summer weather off. then we use Lowe's truck box polish to finish off good for a year. Now in-between we use liquid glass with a micro fiber towel to clean up durning travels our travel blog shows the trailer and trips Vintage travelers safe travels Charles Rondie & Juno
scorpiontimo is offline   Reply With Quote
Old 02-07-2011, 10:37 PM   #45
1965 26' Overlander
Images: 34
Scorpiontimo, I googled Liquid Glass and got a few options. Which one do you use?
Thanks for the heads up.
WBCCI# 2578
Four Corners Unit
Old 02-07-2011, 10:38 PM   #46
1965 26' Overlander
Images: 34
Just thought I would share a quick update we are now 32 hours into our polishing project and have finished step one gray bar on the rear and al of the curbside to the door. We are going to now go back and red bar it the cyclo then move onto the street side. Oh such fun. Funny side note Shawn is now having nightmares about it getting scratched. He said we will have to be cautious about where we camp. I said babe relax it will all be alright. If it scratches we can always re cyclo worst case.
WBCCI# 2578
Four Corners Unit
Old 02-08-2011, 07:48 AM   #47
vintage travelers
1972 31' Sovereign
Images: 20
One thing a mistake I make and Rondie always gets on me for it don't just look at results up close while polishing you will see every flaw and go crazy trying to get it out stand back every so often look at finish from all sides from 5 ft and 10 ft away you will see how good it looks depending on the body you started with you will never get it perfect remember how old it is some scratches are earned and give character and you may always have a bit of discolor like fogging but as a whole it will be just beautiful I changed up this week for I found some fogging on mine went crazy and got out the old gray bar and started to re compound and than back to S grade for polish got most of them little fogies its like starting over I do polish work on the side for some air streamers and had very good results but mine is never done think I will always find a spot to rework.Oh I gave you the wrong cleaner it is called Invisible Glass by stoner it also has a rain repellent work awesome get it through wallmarts and I think auto zone carries it the old stuff liquid glass I use to use than I could not find it anymore so I found this stuff I think it works better it cleans up right after I use the S grade also use it between polishes during the year will put up some new pic's of trailer latter this week after the snow on Wed Charles Sean & Rondie & Juno
Old 02-08-2011, 11:22 AM   #48
BabyBoomers's Avatar
1963 22' Safari
Tulsa , Oklahoma
Anybody tried this stuff?
Sharkhide
BabyBoomers is offline   Reply With Quote
Old 02-08-2011, 12:04 PM   #49
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Sharkhide
Check this out:
http://www.airforums.com/forums/f474...ant-42667.html
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
grinder, polishing
35 foot airstream needs polishing! Skotty34 Cleaning, Stripping & Polishing 13 04-09-2012 07:53 PM
'67 Caravel Door lock Question vonzellen Doors & Locks 14 11-29-2011 01:26 PM
LP regulator question GAT LP Gas, Piping, Tanks & Regulators 17 05-09-2011 07:09 AM
KT lock question Bonitafarms Doors & Locks 5 01-19-2011 05:46 PM
Trailering Question Cracker Jacks, Stabilizers, Lifting and Leveling 14 01-02-2011 02:55 PM
