Old 01-24-2011, 11:43 AM   #29
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Tanks! You're Welcome!
Thought I'd change the discussion to the two aluminum tanks we got for BII.
Something to do on a cold winter day.
The first thing I did was to sand the manufacturing dings and scratches out using 220 grit wet/dry sandpaper on my orbital sander. This took about 2 hours on each tank.
Compounding came next and I used Nouvite F7 on son John's well used 3/8 inch drill and wool pad from doing his Caravelle. The initial results were dismal. The tank wouldn't shine and I was afraid I had ruined the tanks by sanding. So I stopped and reread Shari and Rob's and everyones' threads and viewed all the Youtube videos. What finally clicked was that on one video the guy slathered on quite a bit of F7 where others didn't really address the amount applied. The directions said to use sparingly. Meanwhile I got a new 1/2 inch $25 drill (close out display item) from Harbor Freight and some new wool 6 inch pads. Son John's old one was really cooked.
I started anew with fresh pads and probably a half teaspoon of F7 on the pad.
That worked. I could even hear the high pitched scratching sound one Youtube video mentioned.
So I have completed phase one compounding. Each tank took 2 hours of polishing to erase the sanding swirls and bring out the shine. I think I'll wait for a warm enough day to work outside on the next phase to avoid the mess.
ID:	120013   Click image for larger version
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 01-24-2011, 12:00 PM   #30
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Looking good! I learned that lesson on my last trailer- I always tried to use too much polish. When it seems to dry out quicker it works better..
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-24-2011, 12:35 PM   #31
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
Hello,does anyone know how to achieve the original factory sheen ? Not the mirror shine,Any help would be swell !!
Rollerboy is offline   Reply With Quote
Old 01-24-2011, 12:36 PM   #32
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Looks good Jay! Yeah, too much Nuvite is a bad thing...Rob refers to the "right amount" as a dab about the size of a M&M. Looks like you got the hang of it though...you'll be Cyclo'g before you know it!
At this rate, you'll be ready to bring the Bambi to the May Maintenance Rally!
Shari
Old 01-24-2011, 12:41 PM   #33
InsideOut's Avatar
1956 22' Safari
Images: 108
The closet I have seen to the cleaned up, "like-new-panels - but-not-polished" sheen is either walnut shel or soda blasting. Other than that, any attempt to remove the oxidation on a vintage trailer usually "over-polishes" it or leave unsightly swirls or uneven coloration. Sorry...
I guess the other solution would be to replace all the panels - they aren't "mirrored-finish" from the factory.
Shari
Old 01-24-2011, 01:59 PM   #34
Barrier cream - Wikipedia, the free encyclopedia
Old 01-24-2011, 02:27 PM   #35
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
whats barrier cream for ?
Old 01-24-2011, 04:23 PM   #36
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
The factory panels were clearcoated. That is the sheen you are referring to. If you have them stripped and cleared again they should look like the original finish. However all clearcoating is not the same.
If you strip and clean the surface without highly polishing ( compounding and all) it will ook very good but not mirror shiny. I di my 82 motorhome that way and kept it waxed with a polymer sealant. It looked great and did not blind anyone.
AIR #005
retired!
Old 01-24-2011, 04:41 PM   #37
InsideOut's Avatar
1956 22' Safari
Images: 108
If he's talking about his '63 Sovereign, it most likely never had a clearcoat (it was a rarely chosen option until 1965/6 when it became a standard) so the aluminum panels would be a dull, oxidized gray.
To determine if you do have clearcoat:
  • wash a small test area with warm soapy water
  • let it dry
  • take a tiny dab of toothpaste and gently rub it on the clean skin
  • if it turns black > no clearcoat
  • if it doesn't turn black > there is clearcoat
Shari
Old 01-24-2011, 05:05 PM   #38
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
http://www.airforums.com/forums/f474...set-48187.html please see post number 10.... original shine is what I want ...a nice ,subtle,sexy sheen
Old 01-24-2011, 06:09 PM   #39
InsideOut's Avatar
1956 22' Safari
Images: 108
Well, that trailer was polished and re-clearcoated professionally. Before applying the clearcoat, it was close to a mirrored shine...then the clearcoat is applied which dulls it slightly. P & S is who did the clearcoating - they are also the people that did the walnut blasting on the trailer I saw. They do fabulous work...
Clearcoat application is almost always done professionally, it's tricky needs a very clean environment for a good application and it only lasts about 5-10 years depending on your climate, road rash and whether it's stored indoors or out.
Shari
Old 01-24-2011, 06:20 PM   #40
Originally Posted by InsideOut View Post
That stuff gets everywhere! We have yet been able to find anything that is 100% effective...if you find something, let us all know!
Shari
I was responding to this question....
As the Wiki says, its a cream that you put on your skin, kinda like sun cream, that acts as a barrier between your skin and whatever you are working with.
After you are done, you wash, and it all comes off.
Old 01-24-2011, 06:26 PM   #41
61Ambassador's Avatar
1961 28' Ambassador
1975 31' Excella 500
Bladensburg , Ohio
Lookin' good!
I am eagerly awaiting the time I can start buying my equipment and starting the shine!
Just filed my taxes today - so shouldn't be too much longer now.
The below link has some nameplates, but not the one you're looking for (I don't think so at least):
Airstream Nameplates
61Ambassador is offline   Reply With Quote
Old 01-31-2011, 01:18 PM   #42
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Monday am update... We were awaken this morning early to the sounds of rain down pouring on our roof. Not usually a big deal but our Airstream is stripped down and open to leaks. Not good. It rarely rains in Phoenix then it decides to rain while were polishing So out we went with plastic in the middle of the night to cover her up. Good new is no water inside we caught it early enough. phew.
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
grinder, polishing
35 foot airstream needs polishing! Skotty34 Cleaning, Stripping & Polishing 13 04-09-2012 07:53 PM
'67 Caravel Door lock Question vonzellen Doors & Locks 14 11-29-2011 01:26 PM
LP regulator question GAT LP Gas, Piping, Tanks & Regulators 17 05-09-2011 07:09 AM
KT lock question Bonitafarms Doors & Locks 5 01-19-2011 05:46 PM
Trailering Question Cracker Jacks, Stabilizers, Lifting and Leveling 14 01-02-2011 02:55 PM
