Old 11-27-2009, 12:17 PM   #1
1959 22' Caravanner
candler , North Carolina
polishing question
I have been polishing my 59 caravanner and started to have some problems. When I started polishing with nuvite 7 the results were great and my method was per instructions. But the last few times at applying the polish, I don't seem to be able to polish my finger print smear off the skin??? I have tried a new wool bonnet ,same problem. I would have to use mineral spirits to clean my finger print. What am I doing wrong????
Thanks so much for your help.... Jeff
jeffinwnc is offline   Reply With Quote
Old 11-27-2009, 01:47 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Is all of the clear coat off,that`s what happened to me upon finding places that didn`t strip off good,or you are using too much polish. Dave
easyride is offline   Reply With Quote
Old 11-27-2009, 01:59 PM   #3
1959 22' Caravanner
no clear coat on this 59', but maybe to much polish? thanks
Old 11-27-2009, 02:06 PM   #4
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
There should not be any clear coat on a 59... When you are dabbing the nuvite on the skin don't drag your finger. Nuvite 7 is a liquid form of sandpaper and your finger applies more pressure then bonnet. I use mineral spirits in a spray bottle to clean up the black stuff after I polish a section.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-28-2009, 01:38 PM   #5
1959 22' Caravanner
still puzzled over some areas on my 59'. I posted some pictures and I am wondering if its looking okay for the first cutting with nuvite 7?
ID:	91598   Click image for larger version
Old 11-28-2009, 05:23 PM   #6
1967 22' Safari
1960 Caravel
Images: 8
That looks about right for the amount of oxidation that you have. Good job and keep it up. There's no going back.
Polishing
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 12-02-2009, 05:45 PM   #7
Buffing Supplies
Jester's Avatar
1967 17' Caravel
1966 24' Tradewind
1961 16' Bambi
Piedmont , South Carolina
just curious. How much time have you invested so far.
Jester is offline   Reply With Quote
Old 12-02-2009, 06:13 PM   #8
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
jeffinwnc,
Remember this..nuvite 7 should not be the only compound/polisher you want to be using..
It's a 3 to 4 step process, minimum. The number of steps depends on the degree of oxidation your Aluminum skin has built up over the last 50 yrs.
The results you are getting are consisted with everyone else. To remove the swirls (actually very fine scratch marks) you will need atleast another 2 steps (minimum).
You should be using the Cyclo polisher to get a fine polish shine to the finish.
BTW, don't forget to keep the temp of the Aluminum skin above 60 degrees while doing the compounding/polishing, otherwise, the chemicals gum up when the temp get too low~
Good luck~!
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is online now   Reply With Quote
Old 12-03-2009, 04:59 AM   #9
1959 22' Caravanner
jester, I have about 16 hours in the polishing. I do understand that this is a 2 to 3 step process of polishing. After this first cutting, I will caulk all the seams before going to the next polish.
The temp. might be my problem. I will heat up my shop before the next polishing. Thanks, Jeff
Old 12-03-2009, 09:05 AM   #10
1984 29' Sovereign
Savannah , Missouri
You have only 16 hrs into the polish and so far, it's looking great.
Listen to the metal as it talks to you, and just know this: you have a long ways to go.
The average polish job (it all depends on the length, conditions of trailer, and method used, etc) is several hundred hours.
You will find a HUGE differences once you warm up the work area because low temp does severally impact your work. I once tried to do it when the temp fell below 50F range and, quickly gave up.
Good luck~
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 12-07-2009, 11:38 AM   #11
Buffing Supplies
Jester's Avatar
1967 17' Caravel
1966 24' Tradewind
1961 16' Bambi
I would highly recommend the high speed buffing process. This would cut your time in half and give you a much smoother finish. High speed buffing will remove the oxidation much faster than polishing it away and also remove the scratches from the surface at the same time. Use a 3000-6000rpm right angle grinder. The cyclo is excellent for the final polish. Good luck.
Polishing Project Question kneal Cleaning, Stripping & Polishing 46 06-02-2007 10:06 AM
question about polishing... katzklaw Cleaning, Stripping & Polishing 39 03-25-2007 02:56 PM
Polishing question w/ Walberneze jlandau Cleaning, Stripping & Polishing 12 02-26-2006 10:15 AM
Cyclo Polishing Question JohnG Cleaning, Stripping & Polishing 5 08-20-2004 11:47 PM
