Old 06-02-2007, 12:09 AM   #43
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Kevin, that looks fabulous. Unless I can get mine done soon, I'll be embarrassed to camp next to you. You put me to shame now!
Traveling With Elvis
life with a 1956 Sovereign of the Road
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Old 06-02-2007, 05:33 AM   #44
toastie's Avatar
1955 22' Safari
Great Lake State , .
Originally Posted by kneal
Just about finished the compounding. Just have a few areas to touch up. Now I know why they charge so much to polish a trailer. I probably have about 25 hours in it so far from the compounding/stripping process. Looking forward to hitting the Cyclo next....
Did you forget the one in front of the 2, very hard to believe only 25 hours, sorry...........
toastie is offline   Reply With Quote
Old 06-02-2007, 09:00 AM   #45
1973 23' Safari
Maryville , Tennessee
Images: 13
By 25 hours I mean ACTUALLY working on the compounding...not the time from when I walk out the door work, take a break, clean up, and walk back in the door. If I added all that up that would change the number considerably. You also have to know that my clearcoat was almost flawless so I didn't have any oxidization. I also have a 0-1500 RPM Compounder and have found that if you go at a very low speed with a good bit of pressure you get great results.
kneal is offline   Reply With Quote
Old 06-02-2007, 09:58 AM   #46
toastie's Avatar
1955 22' Safari
[quote=kneal]By 25 hours I mean ACTUALLY working on the compounding...not the time from when I walk out the door work, take a break, clean up, and walk back in the door. If I added all that up that would change the number considerably. You also have to know that my clearcoat was almost flawless so I didn't have any oxidization. I also have a 0-1500 RPM Compounder and have found that if you go at a very low speed with a good bit of pressure you get great results.[/quot
Great job, so the 25 hours is the time that the compounding pad was on the trailer..............
Old 06-02-2007, 10:06 AM   #47
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
25 hours is in line with what I spent on mine.
Dave
Fyrzowt is offline   Reply With Quote
Polishing...approx cost? Drew Cleaning, Stripping & Polishing 10 03-31-2014 10:37 PM
Polishing Again davidz71 Cleaning, Stripping & Polishing 16 11-17-2005 05:40 PM
What Type of Polishing Pad to Use? 68 Suburban Cleaning, Stripping & Polishing 0 10-22-2002 02:28 PM
Anyone else polishing? 64GT Cleaning, Stripping & Polishing 24 08-08-2002 09:19 AM
