03-15-2009, 05:01 PM
1971 27' Overlander
Salesville
, Ohio
Polishing my Airstream
Is it a good idea to strip the clear coat from my Airstream. And if so is it hard to do. The shine is not to bad but would like it to be better.
Hope someone can help.
03-15-2009, 05:05 PM
2006 30' Classic S/O
Mohrsville
, Pennsylvania
Ricker2,
Welcome to the forums. Yes you will have to remove the clear coat before you start into polishing. There are anvironmentally friendly stripers that you spay on, let sit, and wash off with water. Do a search and you will find an abundant amount of information on polishing. Good luck with your project.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
03-15-2009, 05:44 PM
1955 22' Safari
Great Lake State
Check this out POLISHING
03-15-2009, 07:11 PM
1993 34' Excella
Estancia
, New Mexico
I assume you are talking about polishing for a high reflective shine, not just polishing to improve the shine of the clear coat?
Given you want to go for the reflective, stripping the clear coat is the quickest and easiest step. I use aircraft stripper, not very green but effective. You can strip the clear coat in 3-6 hours of work. Brush on, scrape off with a plastic putty knife, rinse with a garden hose (or pressure washer, but it can damage the seams). This is just the tip of the iceberg. Be prepared to spend many, many hours polishing.
Stripping will also make it more shiny in itself. Some folks are satisfied to stop there.
03-22-2009, 02:16 AM
1989 32' Excella
Meridian
, Idaho
Carl, Elaine & Bailey Beagle,
Have you polished your '87? If so, how did it turn out?
03-22-2009, 07:24 AM
Mohrsville
, Pennsylvania
PetesPup,
We took the easy way out and had P & S Travel Trailer Service in Helena, OH strip, polish, and re-clearcoat ours. I asked them to make it look like it just rolled off the assembly line in 1987 and I think they made good on my request. Here is one before and two after pictures. You can also see others in my gallery.
http://www.airforums.com/photos/brow...?c=500&u=14487
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
03-23-2009, 03:58 PM
1989 32' Excella
Meridian
, Idaho
'87 Polish Job
I am Soooooo jealous! Mine looks just like yours did before you had it done. May I ask how much?
03-23-2009, 04:21 PM
Mohrsville
, Pennsylvania
PetesPup,
Check your PM.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
04-13-2009, 06:00 PM
1968 22' Safari
Kalamazoo
, Michigan
Last September I began to polish my 68 Safari... ( link to blog posting)...I am still working on it now. If you check out my blog, I will be posting a quick video in the next couple weeks to give an update on my progress.
It is a process!!!
