Old 01-25-2011, 09:16 AM   #1
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
Polishing frustration
As has been discussed often in this forum polishing an Airstream can be a lot of work. I don't think anything can be as frustrating as removing the old round WBCCI decal. I don't know what kind of glue was used but it doesn't come off easy. Removal, solvents, you name it and it's there. I finally had to use sandpaper to finish and then try to get the scratches off. Luckily I didn't have to deal with numbers.
GAT is offline   Reply With Quote
Old 01-25-2011, 09:50 AM   #2
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Just did mine when I installed new emblems. Took 6-7 passes with F-7 Nuvite.
SilverHoot is offline   Reply With Quote
Old 01-25-2011, 09:55 AM   #3
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
It took us a couple of hours. We ended up using a heat gun and a plastic putty knife. Followed by some remove all to get the clear coat off. It was a real chore. No fun indeed
NicheVintage is offline   Reply With Quote
Old 01-25-2011, 10:16 AM   #4
Ottawa , ON
Our TT gets long white streaks from the decal gunk on it every time we get some rain. I'm hoping that it will run out of the stain material before I get too old to get up on the ladder.
Old 01-25-2011, 10:41 AM   #5
SilverHoot's Avatar
1967 24' Tradewind
Clarification
I did the Nuvite after using Jasco paint remover to remove the emblem.
Just got a 1966 ALANSD 1966 Overlander 365 07-29-2016 03:05 PM
The Fun Begins wasagachris 1973-1974 Excella 500 684 09-26-2014 07:16 AM
35 foot airstream needs polishing! Skotty34 Cleaning, Stripping & Polishing 13 04-09-2012 07:53 PM
Polishing Question NicheVintage Cleaning, Stripping & Polishing 48 02-08-2011 12:04 PM
Polishing details needed... joesurds Cleaning, Stripping & Polishing 11 01-06-2011 11:39 AM
