Old 02-07-2012, 04:03 PM   #1
1981 31' Excella II
New Market , Alabama
Polishing Castings
I know the skin takes a polish pretty well and it stays that way for a while, with castings this does not seem to be the case. I put a new lock in my door grab handle, the one to the right of the door. While I had it off I polished it. I put it on and it looked great but the first time it rained it did not look much better than before the polish. It was starting to corrode.
So the question is what do you do about it.
1. Don't polish and leave it like it is.
2. Polish and it looks like option 1 in a few days.
3. Alodine it and see if that helps
4. Alodine and then follow with clear coat.
I talked to a paint store and they said coat with alodine leave it there for a time then rinse with water. Then coat with $50 a quart clear coat with $32 a can hardener. This would be ok if you had every part on the trailer and you could coat them all at once. I thought Alodine would be a first step and see how long that lasts. If that does not look good then coat with car clear coat after Alodine. The other option is to paint them a uniform gray and be done with it.
http://www.chemical-supermarket.com/...ting-p398.html
Perry
Old 02-07-2012, 05:38 PM   #2
woodja's Avatar
1982 31' Airstream 310
Dayton , Tennessee
I had a similar experience when I polished my bumpers. The bumpers themselves stayed nice & bright but the uprights & the end caps seemed to water spot badly almost from the first rain. I re-polished & then coated with automotive paste wax but it's only a slight improvement. I'll live with it---
woodja is offline   Reply With Quote
Old 02-07-2012, 05:44 PM   #3
1981 31' Excella II
Well I have my battery box access doors off right now to replace the battery boxes and I don't want to spend hours polishing them if they are just going to look like crap after the first rain.
Perry
Old 02-07-2012, 07:04 PM   #4
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Old Chinese Proverb says...
"Learn to live with what you cannot control and control what you cannot live without!" Confus... Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-07-2012, 07:18 PM   #5
"Cloudsplitter"
Perry
Perry,
Did my battery door frames & assist handle two years ago, final wet sand w/2000 and used Griot's Paint Sealer.
ID:	150540   Click image for larger version
Name:	BATTERY DOOR CORROSION REPAIR 007.jpg
Old 02-08-2012, 04:09 AM   #6
1981 31' Excella II
What is Griots paint sealer?
Perry
Old 02-08-2012, 05:04 AM   #7
"Cloudsplitter"
Perry,
All their stuff works well on the Airstream. The sealer lasts very well. Quality operation with great customer service.
Old 02-08-2012, 05:13 AM   #8
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Perry:
I have also heard of a product called sharkhide. I havent used it personally but it has been recomended by several of my metal detailers. Worth looking into.
-C
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 02-08-2012, 05:58 AM   #9
1981 31' Excella II
Bob how often do you use the paint sealer?
Perry
Old 02-08-2012, 06:25 AM   #10
"Cloudsplitter"
Thumbs up
Perry,
Usually every Fall before storage....
How it looked after a nasty WNY Winter.
I've found it longer lasting and easier to use than the Walberstuff.
The Griot's Speed-Shine detail spray werks great for a quick touch-up after washing too.
Name:	SPRING 2009 019.jpg
Interior Polishing Aktundra 1961 - 1963 Bambi 13 09-22-2013 11:46 PM
Polishing in Central Texas area GeoStreamer Cleaning, Stripping & Polishing 4 09-27-2011 05:38 PM
