I have heard that the cyclo with the nuvite/rolite is the way to go. I don't really have the money now for the cyclo. I have tried a 10 inch orbital polisher with little luck but I keep getting a milky film. I find that if I hand apply mothers polish using a lot of pressure for on and off, I can get a decent shine. I have already used the aircraft stripper to get the clearcoat off. Am i trying to use products that will not work? If I get the cyclo/nuvite combo is it going to work like magic? Has anyone else gone from the cheapy polisher to the cyclo and what are the results. I might also add that I heard temperature makes a difference. I live in the desert and it is hot at night, so I must wait a while if it needs to be cool. I'm not doing it in the sun.
Ken, the trailer was heavily oxidized so I started with aircraft stripper. That made a big improvement. The only thing was that it left some spider vein type lines slightly visable. I used Never Dull on a portion of the trailer and that worked well but is a little dificult to apply and remove the residue. Then I used Mothers Polish with a 10 inch orbital polisher. I used about a tablespoon on about a 4 foot by 4 foot section, is that too much or too little? I ran the polisher about 2 minutes on the 4x4 section, is that not long enough? This left the finish not shiny, a milky white film with no mirror reflection. However if I dip a rag in the mothers and hand buff it for a small section in will end up with a clear finish. Or the Never Dull by hand does pretty well, but man is that hard. Thanks for you're help.
I can give you my experience based on keeping up two trailers and reading lots about polishing over the past five years. I have used only Rollite products although I plan to try Nuvite this spring.
There are three grades so you start with the lightest if that does not work then go to a heavier grade. I use a DeWalt polisher that seems to work well. Generally if your trailer is heavily oxidized then you want a more powerful machine than a cyclo or orbital polisher. I think the cyclo is more for finish work.
I'm not sure what the white milk is other than I wonder if maybe you got all the clearcoat off. You can test this with toothpaste - rub in on if your cloth turns black you don't have any clear coat, if not you still have clearcoat on. Two minutes for heavy oxidation probably won't do it.
Polishing is a messy not-to-difficult-but-time-comsuming project, take your time and you will be pleased with the results.
Keep the questions coming a I will do my best to answer.
Yes I did - tried Meguires (sp?), dupont compound, and even heard that cameo pot cleaner worked well. Bought a $10 can of Rollite polish and viola, it worked really good. So then I got a $45 can of their tough stuff (forget the exact name) - then the $10 can then the $45 can of AP-300 then a $16 bottle of sealer. Lots of hours, but it came our really well. If you want you can see my Traveler at www.vintageairstream.com - its the first set of 59 Traveler pictures in the archive section. You will see some fine swirl marks in the finish which over successive annual updates with ap-300 and sealer are mostly gone.
In fact this is my annual polish update weekend on the Traveler. I do the Tradewind in the spring.
I love your trailer. In fact my wife put that on our favorites list. Every time I polish the trailer I ask her if it looks like that one(yours). We got ours about a month ago. Just finished putting in Pergo type flooring and we had the cushions re-covered. Have not tried the toothpick test yet but I will. I'll try to post some pictures.
And was disappointed! A waste of money after finishing the project with Nuvite. The coarsest grade of Rolite is not abrasive enough to remove tough oxidation and or the dreaded MILKY PATCHES.
Numbers speak loader than my words, see the poll on this thread:
I disagree,,, Rolite worked just fine. And a machine will always be faster/easier than hand. You can put as much pressure as you want on a machine. Cyclo will not work well for badly oxidized surfaces.
As I understand it Nuvite is easier to use. In fact I've heard from others that Rolite is better for the badly oxidized skin and Nuvite is easier to use for the finish work.
The reason I have not used Nuvite yet for my yearly updates is because its finish product has a slight "cut" to it whereas Rollite AP-300 is a zero cut.
I not intending to say one is better than another, just that they will both work fine.
Ken ... i'm so upset ... im seeing double posts!! (Just kidding)
I think though (unlike other posts) ... as gentlemen we can agree to disagree without dising each others point of view. I have used both products extensively and hold to my opinion. I respect yours! On the other hand ... want to buy my unused Rolite?
