Old 03-23-2011, 06:57 PM   #1
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Polishing-Black clouds?
I am just starting to polish my 1960 18' Traveler and did one panel. It looked great in the garage but then we took it outside to wash the whole thing and there are black cloud looking things on the polished panel. Also, I was unable to get all the pitting (filiform?) off - any suggestions as to how to get all of it off? We spent about 10 hours on that one little front panel and at this rate we won't be through with it until we're dead.
Have I totally screwed up? What can be done to make the black go away? What did I do wrong to cause that?
I am using the black, brown, and red compounding sticks and a 7" polisher/sander with a sewn buffing wheel. I also have a buffing wheel that has no seams but that didn't take out the black stuff. In addition I have a flat fuzzy cover and a terry-cloth cover for a padded wheel that you use flat on the trailer.
I don't have a cyclo and really didn't want to buy one but will do so if that is the only way to make a mirror finish.
Help!
lucymcdog is offline   Reply With Quote
Old 03-23-2011, 07:21 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
There is a chance you used to much of the black and went thru the alclad. Your best bet now is to use the white bar and try get the final polish on it...get the best you can. A cyclo is probably the best way for this, but a bonnet will do. Use micro fiber cloths and mineral spirits and corn starch or flour as a clean up. I have the same problems with the corrosion pitting still there after polish...I hate it....but live with it.
Old 03-23-2011, 08:07 PM   #3
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
I dealt with this same problem yesterday. I think Melody ranch is on it, but I was able to get it out. From this point on, I will abandon using the black bar, it was tempting because the polishing seemed to go so much faster, but the end result is dissapointing.
To fix it, I had to change from the sewn wheel to the buffing pad, and start with Nuvite G6 on a medium speed. I had to go over it twice, then follow it with F7, then F7 with the cyclo, then Grade S with the Cyclo.
Stick with the brown bar, it takes a little longer but the result is much better.
Also, It is critical that you completely remove all polish between every step.
This is just my experience, so take it for what its worth.
ddstech is offline   Reply With Quote
Old 03-24-2011, 12:15 PM   #4
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
I've not used cornstarch or flour before - do I mix it with the mineral spirits to make a paste or just put some on a rag and wipe the surface with it?
Old 03-24-2011, 12:23 PM   #5
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Use it dry. Just put a little on a micro fiber rag and wipe away. You will be pleasantly surprised. I recommend the corn starch.
Old 03-24-2011, 12:44 PM   #6
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Ditto on the corn starch. It works wonderfully. When I first started my polishing job I also found some of the "black ghosts". I went back over area with compounder and Nuvite 7 then cleaned it off really well. Then went to work with the Cyclo Nuvite 7 again then S. For my money you can't beat the Cyclo.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 03-24-2011, 02:49 PM   #7
1980 20' Caravelle
Coeur d alene , Idaho
Another vote for corn starch with dry micro-fiber rag then Cyclo!!!
Name:	IMG_2637 (Small) (2).jpg
glacierrunne is offline   Reply With Quote
Old 03-24-2011, 05:49 PM   #8
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
OK, you've convinced me that I need a cyclo. I've ordered it and the Nuvite and should have it next week. Now I need to buy another AS so I can justify buying the cyclo...
I'll post pictures when my little jewel shines.
Thanks for the help and advice.
Lindy
Old 03-24-2011, 06:11 PM   #9
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Hey Lindy,
Don't worry bout the cost of the Cyclo. You will need it each year to keep the shine up. In fact I did mine last spring and by the end of summer it needed it again. It still looks great from 50 feet away. Water spots, smudges etc. really do show up in a hurry. The only good thing is the second polish is not as hard as the first.
Tim
TAC MI 14
Old 03-24-2011, 06:43 PM   #10
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Reading about all the labor required to achieve and maintain a high shine makes me glad my trailer is painted silver. I complain about waxing it once a year but that is nothing compared to polishing the aluminum with bars, rags, cyclos, etc...
4RXLA is offline   Reply With Quote
Old 03-24-2011, 08:08 PM   #11
ddstech's Avatar
Folsom , California
I do envy you to some degree, but the little voices in my head keep yelling at me to keep polishing....
Old 03-24-2011, 09:13 PM   #12
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Originally Posted by tkasten View Post
Hey Lindy,
I do love those shiny little trailers! And yours is beautiful! But polishing twice in one year? Does it ever end???
What about doing a clear coat on it?
BTW, did you make your rock guard? Got any closer-up pictures? If you didn't make it, where did you buy it?
Where did you guys get your awnings? Ah, yet another several hundred dollars I can spend on a 50 year old trailer!
Old 03-25-2011, 03:41 PM   #13
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
question
There are a few panels on my trailer that, after removing the clearcoat, are quite shiny. Can I get by with just using the "S" and the Cyclo or do I still use the wheel and the brown and/or red compound on it?
Old 03-25-2011, 04:19 PM   #14
1980 20' Caravelle
As long as there is little if any filiform, on the shiny panels just use the cyclo F7 or S. I've learned a lesson don't use the black/brown bars unless there is alot of filiform! Just my two-cents. Don
Is there anything wrong with this polishing? poezlaw Cleaning, Stripping & Polishing 18 02-06-2012 03:35 PM
sticky black tape between interior skin & frame? clipperguy Ribs, Skins & Rivets 1 03-21-2011 04:00 AM
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 06:50 AM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
Polishing frustration GAT Cleaning, Stripping & Polishing 4 01-25-2011 10:41 AM
