Old 11-27-2007, 07:58 PM   #1
1968 26' Overlander
Ann Arbor , Michigan
Images: 11
Polishing AS in Winter
I know this sounds crazy but I would like to polish my AS. It will be under an overhang...so...what is the best weather to polish in.
Aluminati is offline   Reply With Quote
Old 11-28-2007, 06:28 AM   #2
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I would say any season that is not camping season. In my limited experence, any weather that you can tollerate and is not too hot on the surface. Cool is more pleasant and works just fine. It can get too cold for my fingers to work much below 45F however.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 11-28-2007, 06:35 AM   #3
1968 26' Overlander
Images: 11
But there is not an issue with it being to cold for the compound or polish to work...correct? I also have to strip the clear coat off of it. I would have to say that I am impressed that still has the original clear coat on it....its not even peeling to give me a head start
Old 11-28-2007, 06:53 AM   #4
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
IMHO if the clearcoat is in tact, save yourself a lot of grief and leave it alone.
jkcru is offline   Reply With Quote
Old 11-28-2007, 07:00 AM   #5
1968 26' Overlander
Images: 11
I wish I could...but I cant...something inside wont let me
Old 11-28-2007, 07:02 AM   #6
Royce's Avatar
Amen! if the clearcoat is fine wait until it is not, to polish, and enjoy the coach as is. If you insist on polishing then here are two sites to get you started. Also check out the search function on this forum, lots of good info.
Home
Polishing
AIR# 3913
Old 11-28-2007, 07:42 AM   #7
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Originally Posted by Aluminati
But there is not an issue with it being to cold for the compound or polish to work...correct? ...
No, I don't think that's correct. When it's too hot the compound "dries" out too fast and you don't get good polishing action. When it's too cold I suspect the viscosity of the compound is too high and it would act just like it was dry--high drag on the polisher and not much polishing action. This would be dependent on skin temperature, so if you're polishing like a tornado, maybe it would be warm enough.
I think of this stuff like using a wet whetstone--works a lot differently than a dry one. So too hot means very short polishing time per dab, too cold means like using cold molasses.
Give it a shot and let us know if it really can be too cold.
Zep
Old 11-28-2007, 08:19 AM   #8
jkcru's Avatar
If you must then good luck and best wishes.
Old 11-28-2007, 08:25 AM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
My experience on removing the clear coat from my trailer was that temperature mattered. It needed to be warm for the remove all to work, although I suspect that lower temperature can be offset by letting the remove stay on longer. The limiting factor there would be you don't want to let the remove all dry out. Not sure how the compounding would turn out. Let us know how it turns out.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 11-28-2007, 08:35 AM   #10
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Its the stripper
The stripper will not work effectively at all. It will work some....but slow and partially. I think the instructions on the label even say so and give temp limits. The polish part should go O.K.
P.S. I hate working in the cold.
Old 11-28-2007, 08:36 AM   #11
1969 31' Sovereign
atlanta , Georgia
I'm in the finishing stages of a mirror polish on my '69 31' - it is a massive amount of work, but well worth it. the stripper works in relatively cold weather and the Nuvite compounds do as well. What I have found though is that if you dab the compounds on you are standing a much higher liklihood of spinning it right off, I have found that if you apply by hand rubbing and follow up with grinder/polisher the results are much better. I know it sounds rediculous to massage compound, but it works, particularly on edges and tight spots
nunya001 is offline   Reply With Quote
Old 11-28-2007, 08:48 AM   #12
Ken J's Avatar
Durango , Colorado
Images: 14
In my experience, polishes do not work well much under 65 degrees
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-28-2007, 08:55 AM   #13
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I agree with Ken.
You have about a 15 degree window. At close to 60 degrees the polishing turns to a powder and does not work.
Closer to 80 degrees it just smears and is equally useless.
Ideal is 65 - 75 degrees. If you have shade you may be able to push the upper end some.
-Tim
theVAP - Airstream Podcast
Old 11-28-2007, 11:41 AM   #14
1968 26' Overlander
Images: 11
Originally Posted by Safari Tim
I agree with Ken.
O.K...I guess I will wait until spring because I will be working outside and I dont want to screw anything up.
Thanks to all who have replied
Winter is over azflycaster Off Topic Forum 19 05-04-2007 07:26 AM
Winter Cover- 2006 Classic ITowSilver 2006 - 2010 Classic (all lengths) 7 03-22-2006 08:16 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Winter use ???? donnall General Motorhome Topics 3 01-08-2005 07:33 AM
Winter Driving ajjohnsons Our Community 6 12-09-2003 06:48 AM
