Old 04-15-2010, 01:51 PM   #1
1962 22' Safari
Joppa , Maryland
polishing and towing
Hello, I am new to the forum and enjoy reading the threads.
I am in the planning stage of restoring a 1962 Safari 22 ft. To start could someone share thier experience in restoring the exterior aluminum skin.
Also I plan to use 2000 Ford explorer as a tow vehical. Will it do the job?
You can post, email artel99@verizon.net or ph. 410-937-2786
Thanking you in advance,
shinny1
shinny1 is offline   Reply With Quote
Old 04-16-2010, 06:36 AM   #2
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Shinny:
Welcome to the forum! You might get more response if you split your questions into two threads. Responding to your restoration of the aluminum skin question, do you mean polishing? There are many threads on polishing. Check out a list of polishing threads here. Let us know what you are looking for!
-Tim
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 04-16-2010, 06:46 AM   #3
65CV's Avatar
Western , Massachusetts
The vendors of polishing products have simple how-to's:
Vintage Trailer Supply
Polishing Advice
Perfect Polish Video:
How to Order
Welcome to the forum! You found a great trailer.
John
65CV is offline   Reply With Quote
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Polishing help walter1 Cleaning, Stripping & Polishing 8 10-13-2004 09:10 AM
polishing jimmy Cleaning, Stripping & Polishing 0 07-20-2003 12:22 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
