Old 08-16-2002, 01:44 PM   #15
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Bathroom vent fan
Vern,
Sorry for the delay of my pictures. Here is an outside and inside picture of my bathroom fan. It is a smaller fan than yours from what I gather.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-16-2002, 01:45 PM   #16
davidz71's Avatar
1986 25' Sovereign
Inside view.
Craig
AIR #0078
3.73 rear end
Old 11-17-2005, 05:40 PM   #17
amron's Avatar
1953 25' Cruiser
Sterling , Virginia
Images: 13
Originally Posted by davidz71
Vern,
Last summer I pulled the stainless exterior cover off the bath exhaust fan and found silicone used to seal the edge of the fan. I didn't know it at the time but once silicone caulk is used, Vulkum will not stick to the aluminum. I cleaned around the area with gasoline, let it dry then sealed around the fan with the Vulkum. I then put a thin coat around the edge of the stainless bowl as I screwed it down. It has slowed down the leak which was coming straight down into a pan. When I start polishing later on, I will remove the cover again and polish right up next to the fan. Maybe that will get rid of the silicone residue. I also have to do this with my awnings. I found silicone there also so stripped it off and sealed with Vulkum. Same result as the exhaust fan. Oh well, live and learn.
use m.e.k.(methyl etheyl ketone) at lowes, to remove silicone
amron is offline   Reply With Quote
After polishing; Always the same question; NO reply ! brunoffrance Cleaning, Stripping & Polishing 6 06-14-2014 08:43 PM
Polishing almost half done already! drboyd Cleaning, Stripping & Polishing 39 10-14-2004 10:09 AM
polishing a 91 limited 0557 Cleaning, Stripping & Polishing 1 02-18-2004 06:49 AM
Serious about polishing... Safari Tim Cleaning, Stripping & Polishing 2 08-31-2003 08:23 AM
Polishing Inland RV Center, In Cleaning, Stripping & Polishing 1 08-13-2003 05:25 PM
