Old 03-25-2014, 12:41 PM   #15
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The 70's vintage trailers had clear coat applied to them, but by now, much of it has probably disintegrated and washed away. You will likely need to use a stripper on the vertical sections, but the more horizontal sections may already be clear coat free. The best toothpaste to use is the old opaque "pasty" type, not a gel. The black stuff is aluminum oxide that is coming off. If there is a clear coat, then you won't do anything but smear toothpaste on your trailer. It takes a few minutes of rubbing to get the oxide moving.
Old 03-25-2014, 12:48 PM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I don't have anything your vintage but I believe you have the plasticote type clearcoat.
Old 03-25-2014, 01:23 PM   #17
Belegedhel's Avatar
Houston , Texas
The clear coat that was on the majority of my '73 bubbled up at the touch of the Aircraft stripper. The stuff that is on the "new" segment is bullet proof--seems to be invulnerable to any chemical--I'll try the Marine stripper if I can find it and it has anything more hostile than the Aircraft stripper, otherwise, I'll be breaking out the sand paper.
Old 07-07-2014, 06:30 PM   #18
Charlotte , North Carolina
So, it's been 6 months. What happened to the new panel? Did you sand? How did it go?
Lisa
lisaslists20 is offline   Reply With Quote
Old 07-07-2014, 06:30 PM   #19
oooops. it's been 3 months, lol.
Old 07-07-2014, 08:33 PM   #20
Belegedhel's Avatar
Houston , Texas
Well, I started working on the interior, thinking that I would get back to the exterior once I have a bed to sleep on. I did buy some Marine stripper stuff, but I am not sure that it is the stripper of myth and legend--I'll give it a try here pretty soon...
Old 07-08-2014, 06:18 AM   #21
on a vintage sewing machine group, i just heard about soda blasting used on aircraft? "gentle" sand blasting?
Old 07-08-2014, 06:51 AM   #22
1981 31' Excella II
New Market , Alabama
I expect the new stuff weakens with exposure to UV as most polymers do. Colorado is not very hot but they get tons of UV due to high altitudes and lack of clouds and humidity. I expect the UV damaged plasticote is much easier to remove than the new stuff.
Perry
Old 07-08-2014, 07:23 AM   #23
Belegedhel's Avatar
Houston , Texas
Soda blasting, eh... Well, I haven't gotten that desperate yet. Plus, I have had metal parts sand blasted in the past, and they typically protect threaded surfaces with a bit of masking tape, so this plasticote may be pretty resistant to light blast media. Vintage sewing machines, now--that's interesting too. I have a Singer 7-34 sitting on my work bench trying to compete with my Airstream for attention...
Old 07-08-2014, 07:46 AM   #24
I will someday be in the market for a morse 4300. blue. i love them.
Interior Polishing Aktundra 1961 - 1963 Bambi 13 09-22-2013 11:46 PM
Segment protectors jstokes Rock Guards, Segment & Window Protectors 0 10-07-2011 05:42 PM
segment removal and replacement purdytj Ribs, Skins & Rivets 1 07-22-2011 08:39 AM
