Old 07-31-2011, 05:28 AM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Polish Residue Removal
I'm grinding away on my Airstream with Nuvite polishes. I'm getting there, but still a ways to go. I use lacquer thinner to cut the residue, and then use corn starch to get more of it off. This process does not get all the "cloudy" black stuff off.
What is the best way for removing black polish residue?
David
Old 07-31-2011, 06:15 AM   #2
oldtrucksrul's Avatar
2009 27' FB Classic
Southlake , Texas
I like mineral spirits.
oldtrucksrul is offline   Reply With Quote
Old 07-31-2011, 06:24 AM   #3
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I used mineral spirits when compounding (N7) then corn starch w/micro fiber towels for the Cyclo with Nuvite S. The micro fiber towel seems to brighten the shine.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 07-31-2011, 10:00 AM   #4
reinergirl's Avatar
Hollis , New Hampshire
Try flour! Colin Hyde showed me this trick and it seemed to work!
reinergirl is offline   Reply With Quote
Old 07-31-2011, 10:07 AM   #5
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
All of you are sooo close...thats right, you are getting warmer....warrrmer....Laquer thinner dries to fast and will not only blister your brain and digits, but dries so fast that there is hardly any time to pick it up. Use Kerosene. It stays wettest of all the cleaners and even sort of conditions the aluminum. Oh here are some flamingos for you guys---I asked the owner of theis restaurant if I could do a mural of a flock of flamingos and he said go for it. This is just the beginning of it.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 08-01-2011, 04:35 AM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you for the tips !
Thank you for taking the time to help me. I was using lacquer thinner and terry cloth. I found it diluted the polishing mud and spread it around, but left a lot on the surface. It may even make it thin enough to embed in the pores of the aluminum. Corn starch and terry cloth doesn't get it all either.
I heard kerosene works pretty well, and I will try that.
David
Old 08-01-2011, 04:47 AM   #7
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Amonia Free cleaner
and good old Elbow grease!!
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 08-01-2011, 08:03 AM   #8
Baltimore , Maryland
... so many methods, so many opinions. I wonder who is right? I am going with Rob. I use the same method as him.
Old 08-02-2011, 04:55 PM   #9
We used mineral spirits and it got all of the black residue off pretty well. We found that we needed to wash the surface off that was polished with water the same day to avoid a wierd rainbow effect (not sure if this was due to the mineral spirits or the polish).
Old 08-02-2011, 06:30 PM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Works for me.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 08-02-2011, 06:58 PM   #11
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have had good luck with diesel fuel. It dries even slower than mineral spirits or kerosene.
May actually take a day or to to dry if it is near freezing out.
I wash it off with hot water and Dawn dishwashing detergent
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Strip & Polish 89 Excella 32' cjack99 Cleaning, Stripping & Polishing 14 04-06-2012 10:03 AM
Exterior Paint Removal star kitty Clearcoat, Exterior Paint & Trim 4 07-30-2011 01:19 PM
Seal or Polish first JIMandPJ Ribs, Skins & Rivets 4 03-14-2011 11:58 PM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 10:46 PM
'75 TW fresh tank removal 1 man Breadbug Fresh Water Systems 4 02-01-2011 07:31 PM
