Old 08-17-2010, 06:59 PM   #1
1972 23' Safari
Medford , New Jersey
Polish Replacement Panels on 72 Safari
We have a 1972 Safari that was involved in an incident that cause the right rear lower and upper panels on the corners to be replaced. The panels were replaced with new panels. Insurance would not pay for vintage panels. We are polishing the trailer and would like suggestions on what to do.
Of course the obvious answer is buy vintage panels. Easier said then done. What can we do with these existing panels. If the only option is buy vintage panels, where can we get vintage panels at a good price.
Thanks for you help and advice.
srotkowitz is offline   Reply With Quote
Old 08-17-2010, 07:25 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Good question. I've had to replace three dented panels on the rear of my '72 Sovereign. You'll need to strip the clearcoat from your new panels before you polish them. You'll be able to polish them, but I've been told they won't be as brilliant as the old vintage ones.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 09-18-2010, 09:30 PM   #3
Buying a quality sheet of aluminum is the best thing you can do and even then that's not usually enough. Try to work your polisher on a 45 degree angle relative to the "grain" of your sheet F7 or G6 polish is a must. Then consider the acid bath or a wet sanding with 2000 grit sandpaper these are "experimental" techniques so experiment on a scrap before you try it on your trailer.
Chizlam is offline   Reply With Quote
accidents, polish, polishing, vintage airstream, aluminum
Adding Solar Panels to a Safari 25' FB AronS Generators & Solar Power 24 05-29-2014 09:34 PM
half polish, dull, or matte, polish techniques ? greenrig Cleaning, Stripping & Polishing 9 07-11-2009 10:11 PM
Axle Replacement on Safari 23 kneal Axles 18 02-27-2007 02:47 PM
Argosy Replacement Panels woody_strohm Ribs, Skins & Rivets 4 09-03-2003 06:39 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
